Thermostat wont open, its cold out and im freezing my a$$ off
Ok, i have a 91 civic wagon, 2wd for a beater..
Things replaced/fixed:
New radiator, coolant flush, t/b w/water pump, radiator cap, 180 degree thermostat...
Problem/s:
The car wont stay at normal operating temperature. It also seems that the thermostat isnt opening up..
after idleing to get the bubbles out for 30 min, i came back to the car, and the coolant temperature gauge is pointing at "C"
also the lower radiator hose (after the thermostat) is cold/luke warm
Modified by USDM EG at 10:00 AM 12/5/2006
Modified by USDM EG at 10:01 AM 12/5/2006
Problem/s:
the thermostat doesnt effect your heater temp (unless its stuck wide open)
check to see what position your heater valve is, its under the fuel filter. your cable might not be pulling it open all the way.
it should be pointing toward the hose to be open
closed is 90 degrees from hose.
gl
gl
Yeah, it's definitely not opening. Might be a dumb question, but you installed it with the bleed hole facing up, correct? You can check if it's defective also by putting it in a pot of boiling water and see if it opens up. No sensor should affect it opening / closing because it's mechanical. Maybe you have ablock in your cooling system? Just throwing some stuff out there, I want you to get it fixed ASAP as well, it's getting seriously cold up here. Good luck
bleed hole is up, and a new gasket as well...
I doubt its a block... when i took the old thermo out.. coolant poured out like crazy!
I first installed a 195 thermo last week, today i swapped it out for a 180 thermo.. on the 195 is stayed at N.O.T., but with the 180 is doesnt blow warm air unless im above idle...
if your thermostat WAS NOT opening your car would be overheating, if its stuck open your car wouldnt warm up.
are you sure your gauge is right??? the only way your car will overcool is if the coolant is constantly flowing (stuck open thermostat).
so either, your gauge is wrong, and your engine is reaching operating temps, but coolant isnt reaching your heater core, OR your water pump is defective and not pumping enough coolant at low rpms to allow coolant to pass over the heater element.
To get air out of the system I believe you start it when its cold(the engine) and have the radiator cap off and let it just idle for 10 min or so till the engine fan kicks on, when the fan kicks on I believe all the air is out of the system. Hope this helps
dbailey
11
Jan 30, 2020 04:27 AM
