91 Accord ALB light??
Old Dec 5, 2006 | 03:27 AM
seelyd's Avatar
Default 91 Accord ALB light??
The ALB light on my 91 EXR came on and I'm not sure what it means exactly. I figure that it has something to do with the brakes?? I checked the brakes and lines and everything is good, no leaks and the rotors and pads are brand new. Anyone have any ideas of what I should be looking for or what exactly that light means??? Thanks for the help
Old Dec 5, 2006 | 09:33 AM
hondadude's Avatar
Default Re: 91 Accord ALB light?? (seelyd)
you need to OPEN THE HOOD, and check to see if there is brake fluid in the ABS reservoir. Can you hear the ABS pump run when you start up the car?
Under the hood there is a small fuse box that has a relay and 3 fuses in it, you can pull those fuses to reset the ABS control unit. You can also pull the relay out and jumper across the larger connections to see if the pump wil run.
Old Dec 5, 2006 | 09:58 AM
seelyd's Avatar
Default Re: 91 Accord ALB light?? (hondadude)
There is brake fluid in the ABS resevoir, so I will try the fuse reset. Thanks for the help!
IT'S ME DAVID
Mar 17, 2009 01:57 AM
socialistic
Jan 18, 2008 05:09 AM
unKnown
Jul 12, 2004 04:31 AM
forksports
Oct 20, 2001 11:14 AM
