Help with speedometer! it's acting up...
Old Dec 4, 2006 | 07:06 AM
8YourV8's Avatar
Default Help with speedometer! it's acting up...
Mmmk let's see. Around 1 out of 10 times when I start up my '94 integra GSR and drive, the speedometer doesn't work. However, at speeds of 50+ mph, the speedometer ALWAYS bounces up and down very rapidly from down past 140 mph all the way back up to 50-60 mph. Loose connection maybe? Help/advice needed please, thanks.
Old Dec 4, 2006 | 09:46 AM
8YourV8's Avatar
Default Re: Help with speedometer! it's acting up... (8YourV8)
bumpitty bump
Old Dec 4, 2006 | 12:58 PM
8YourV8's Avatar
bump
Old Dec 4, 2006 | 01:54 PM
87shytwhip's Avatar
spedo's busted.. and or vss sensor needs to be changed..
Old Dec 4, 2006 | 05:12 PM
JasonST's Avatar
Default Re: Help with speedometer! it's acting up... (87shytwhip)
Do u have the cel for the vss? If not, sounds like the bouncing could be caused by a loose connection, or a bad ground, so check the connector to the sensor and check all ur grounds, especially the thermostat ground.
Old Dec 4, 2006 | 07:41 PM
99Geeezer's Avatar
try disconnecting the vss wire. spray it out with some contact cleaner and reinstalling with a little bit if dielectric grease.
Old Dec 4, 2006 | 09:09 PM
8YourV8's Avatar
well thanks guys ill do some checks tomorrow.... later today rather. ****** sucks havin to do this stuff with snow on the ground... MA just got our first little taste of winter and im not liking it one bit. maybe if i bought an Evo.... lol
Chrizcrozz
Aug 31, 2011 09:33 PM
hbhonda
Oct 20, 2009 06:34 PM
dc2much
Apr 7, 2008 03:58 PM
blkhtch98
May 30, 2005 02:03 PM
RemerLex11
Mar 5, 2005 11:23 AM
