do my motor mounts need to be replaced?
Old Dec 3, 2006 | 10:05 PM
wstsydr's Avatar
Default do my motor mounts need to be replaced?
ok, here's what is up, i have done an engine swap in my 94 prelude (h23a1 -> h23a) and after i got it all done, i was noticing i get waay too much movement in the engine, and it makes the downpipe and the front of the rest of the exhaust vibrate on the underbody. i was wondering if you guys thought that i needed to replace the motor mounts with stock ones, not going to race the car, or if i should just get inserts. i also just found out tonight that there is a certain order in my helms, and was wondering if that would contribute to the movement. sorry in advance if this has been covered i did search and all i found was mainly performance seekers and stiffer mounts, which i dont really need, just want the most comfortable ride possible.
Old Dec 4, 2006 | 02:37 PM
nonvteclude's Avatar
Default Re: do my motor mounts need to be replaced? (wstsydr)
the inserts would help alot. it would definately be cheaper then getting all new ones.
Old Dec 4, 2006 | 07:16 PM
capsule
Guest
Posts: n/a
Default Re: do my motor mounts need to be replaced? (nonvteclude)
Also if they have the Ingall's engine Torque Dampener for you application. I tore my front mount on my 99 lude from engaging with my ACT Clutch. I installed the torque dampener and the engine is more stable. You can feel the difference.
Old Dec 5, 2006 | 08:15 AM
wstsydr's Avatar
Default Re: do my motor mounts need to be replaced? (capsule)
thanks for the replies, helps a lot
Old Dec 5, 2006 | 08:35 AM
iwubmybb4's Avatar
i dont think they make an engine damper for 4th gens, i've looked. I heard we can use an accord engine damper with a few modifications? can someone else confirm this?
Old Feb 13, 2007 | 07:05 PM
Pssst!'s Avatar
Default Re: do my motor mounts need to be replaced? (iwubmybb4)
ttt
Old Feb 13, 2007 | 07:32 PM
Default Re: do my motor mounts need to be replaced? (Pssst!)
yes the accord one will work with modification. i ran one for a while, you just have to open the bolt holes up
Old Feb 13, 2007 | 11:13 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwubmybb4 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think they make an engine damper for 4th gens, i've looked. I heard we can use an accord engine damper with a few modifications? can someone else confirm this?</TD></TR></TABLE>
Yes, drill 1 hole larger on an NRG Accord damper. I've posted the pic of the one I used to have a bunch of times...
Old Feb 13, 2007 | 11:20 PM
smackdown's Avatar
Default Re: do my motor mounts need to be replaced? (Hawkze_2.3)
mine too i can feel like somthing is loose when i take off what year of accord though for the stiff mounts??
Old Feb 14, 2007 | 07:41 AM
Hawkze_2.3's Avatar
Default Re: do my motor mounts need to be replaced? (smackdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smackdown &raquo;</TD></TR><TR><TD CLASS="quote">mine too i can feel like somthing is loose when i take off what year of accord though for the stiff mounts??</TD></TR></TABLE>
Read the thread again...
Old Feb 14, 2007 | 09:51 AM
smackdown's Avatar
sorry bout that .. i was refering to the ingalls torque damper from accord to fit a 4th gen prelude..
Old Feb 14, 2007 | 10:21 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smackdown &raquo;</TD></TR><TR><TD CLASS="quote">sorry bout that .. i was refering to the ingalls torque damper from accord to fit a 4th gen prelude.. </TD></TR></TABLE>
That's cool...the NRG damper is the same thing and it's less than 1/2 the price.
Knightmare69
10
Sep 25, 2006 12:56 PM
Akalima
Apr 16, 2006 03:20 PM
vti444
Nov 14, 2005 02:19 PM
Bbasso
Mar 4, 2005 05:48 PM
ekoms31
Jun 1, 2004 09:19 AM
