E-Brake light stays on
Like the title says, I've got another problem. Its the E-Brake light on the HUD that just stays on after I've put the handle down.
This just started yesterday after the lude sat out all night (its cold) and happened again today after sitting out while I was at work (its garage kept).
I know that the brakes aren't sticking because the car will roll down a hill and I can push it when its in neutral. Anybody know whats going on?
Thanks,
Scott
Thanks,
Scott
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ulanky »</TD></TR><TR><TD CLASS="quote">Like the title says, I've got another problem. Its the E-Brake light on the HUD that just stays on after I've put the handle down.
Thanks,
Scott
You should see if your e-brake cable is tighten anyways. Doesn't hurt to try.
Thanks,
Scott
</TD></TR></TABLE>You should see if your e-brake cable is tighten anyways. Doesn't hurt to try.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JerricksOn »</TD></TR><TR><TD CLASS="quote">check your brake fluid. it might be low</TD></TR></TABLE>
^^^ yea what he said!
Well, my fluid was full (I checked that when the problem first arised)
Its actually a problem; I pulled this from another site if anyone else is having this problem.
OK I looked it up and the is the jist of it.
Service Bulletin 03-078
Affects
96-00 Civic
97-01 CRV
97-01 Prelude
98-02 Accord
Parts need to fix the problem.
Filter part #46666-S04-J02 List of $5.08
Float part #46662-S84-999 List of $1.92
Try that and it should fix the problem
Affects
96-00 Civic
97-01 CRV
97-01 Prelude
98-02 Accord
Failing that try lifting the centre console and spraying some WD-40 into the ebrake electrical contact switch, you might just have sticking contacts in the switch.
P.S. adjust it while you can get at the adjuster at same time.
Number 5 Switch in this diagram : http://www.hondaautomotivepart...BRAKE
Modified by britishdude at 7:21 AM 12/8/2006
damn same **** happened to me and then a day later the abs light went on....i rotated my wheels bc my dad said it might be the tire pressure...but it went away after like 2 days...how long has it been like that...???
T--Rex
Dec 22, 2004 05:54 AM
AlphaQup
Oct 12, 2004 07:14 AM
