recoating cams?? is it possible?
Old Dec 3, 2006 | 12:20 PM
bluedlude's Avatar
Default recoating cams?? is it possible?
so i have a chance to get my hand on some type S cams really cheap. the problem is, the guy thats selling them told me his timing was off a couple teeth so the rockers started rubbing the lobes on the cams pretty hard and wore the coating off of them. is it possible to get the lobes recoated?
he also said that he measured them and they were at the same spec as another set he had.
Old Dec 3, 2006 | 02:32 PM
Charliegrs's Avatar
Default Re: recoating cams?? is it possible? (bluedlude)
there are some anti-friction coatings that are commonly used on pistons to increase theyre durability and produce less friction. they are also used on other components. very popular with the domestic v8 crowd. im willing to bet you can use these coating on your cams, you may have to get the cams ground a little bit because of the wear. your best bet is to get in contact with one of the companies that does these coatings and ask them if you can use it on your cams but i think your ok
Old Dec 3, 2006 | 03:46 PM
InvaderTrax's Avatar
http://www.deltacams.com
If the cam lobe is damaged, you're only option is to get them reground
Old Dec 4, 2006 | 10:59 AM
bluedlude's Avatar
Default Re: (InvaderTrax)
the lobe isnt really damaged, he said its just worn moreso than usual? i mean, if you can do regrinds then wouldnt it be ok?
Old Dec 5, 2006 | 05:20 PM
BlUAc's Avatar
Default Re: (bluedlude)
ya your best bet is to get it reground then kevlar coated
Old Dec 5, 2006 | 05:49 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">http://www.deltacams.com
If the cam lobe is damaged, you're only option is to get them reground</TD></TR></TABLE>
Your link doesn't work.
Besides, none of you guys have any experience at all with coating cams do you? So, keep you BS opinions to yourself unless you have some evidence to back it up.
bluedlude: post pics of the cam lobes
Old Dec 5, 2006 | 06:50 PM
bluedlude's Avatar
Default Re: (bb4ever)
i say to fishy cams. i say to saving my money for some H22X goodness
Old Dec 5, 2006 | 06:51 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">i say to fishy cams. i say to saving my money for some H24X goodness</TD></TR></TABLE>
edited
Old Dec 5, 2006 | 06:53 PM
bluedlude's Avatar
wouldnt that be overcamming on a street 11.5:1?
Old Dec 5, 2006 | 06:59 PM
mgags7's Avatar
what is the rest of the setup?
those cams aren't THAT big, they have bigger lift, but their duration is much less than the JUN cams....
Old Dec 5, 2006 | 07:25 PM
bluedlude's Avatar
unless i really figure out this F23 crank thing, ill just have type S pistons on the stock H bottom end, prolly clean the head up 0.010", get high compression valves. should put me somewhere around 11.3 - 11.5 CR. euro R manifold hopefully. some ghetto *** header with a 2.5" collector. somthin like that. oh yeah, i ported my head too.
Old Dec 5, 2006 | 08:18 PM
http://www.deltacam.com
Sorry
Angel4768
May 23, 2011 09:49 PM
psegs80
K Series
Nov 25, 2009 08:27 AM
