cant get ride of code 5!!! :thumbdown:
i cant get rid of code 5 (water temp i believe) i hook it back up for the first time since the head got replace and started it up, let it run for about 10 minutes... the temp gauge works fine now....
BUT
im still throwing code 5, i reset the ecu ...nothing
also when i use the signals the temp needle bouces up in the hot range, but only when the check engine light is on
idk what to do!!
my car is a 91 si with b16a obd0 swap
BUT
idk what to do!!
drove the car to work today, on the way home (a few blocks from home actualy) the needle went red hot, my heater was blowing ice cold air, and when i went to check everything out (no clue what to exactly look for) i found nothing.... only thing i thought was outa wack is that the lower radiator hose was ice cold (like no fluid was goin through it?)
help! this is my daily driver
There is no code 5, code 6 is the coolant temp sensor so I'll assume its that.
The lower hose should be cooler than the top hose but not very cold, was the top hose hot? If not then start with your thermostat. You can just remove it, take it for a good spin and see if you have an overheating issue and also check your hoses for temp. Then you just replace the thermostat. Did the heater work before the swap? If so has it worked since the swap or has it just recently gone out?
opps 6* thats what i meant.
yes the heater has always worked PERFECTLY, on my way home last night when my car decided to start geing gay it stopped working.
the ower radiator hose is ice cold after taking it around the block. the upper radiator hose is normal (nice and warm)
so you think my therostat is stuck? just replace it?
or what should i do
or what should i do
