d16 trans. slop, play?
Old May 10, 2002 | 05:41 AM
SoloSol's Avatar
Default d16 trans. slop, play?
I've noticed some play or slop in my 93 delsol trans. This happens when i accelerate, and or have a load on the driveline then let off . When i lift it seems to be very"free" like its coasting with out the weight of the car. Then it seems to catch up. When it does the car sort of rocks forward, and I feel the engine braking and trans slowing the car. This is like the play that you can feel when you rock your car back and forth (when its in gear engine off and parking brake down), but more of it Is this normal? It seems excessive to me.
Note: The car has ACT hdss clutch and 125k mi.
[Modified by SoloSol, 6:43 AM 5/10/2002]
Old May 10, 2002 | 06:05 AM
sgT's Avatar
sgT
Default Re: d16 trans. slop, play? (SoloSol)
sounds normal to me.
D series trans are sloppy. not as sloppy as accord/prelude though
Old May 10, 2002 | 09:57 AM
Mista Bone's Avatar
D Tranny Guru
worn engine mounts, get some ES inserts and only use the rear one.
Old May 10, 2002 | 11:02 AM
SoloSol's Avatar
Default Re: d16 trans. slop, play? (Mista Bone)
Thanks guys both answers sound good to me Ill try the es inserts and see what I come up with.
Thee_Antic
Oct 28, 2011 09:29 PM
Bonkvader
Mar 14, 2011 04:20 PM
jdmcivicracer89
Oct 11, 2007 10:54 AM
ScottEK
16
Sep 26, 2002 09:35 PM
