Brakes or struts?
Old May 10, 2002 | 05:31 AM
BigZ88's Avatar
Default Brakes or struts?
Ok, I am planning on swapping my engine within the next year. Right now, I am running stock brakes and struts. I have GC coil overs. My question is this. Do i go for a big brake upgrade, or do i go for the whole shebang and get the entire kit and get calipers too? Also, should i worry about that or struts first? I have factory struts on my car right now. What is the better investment first? I am trying to prepare myself now. I want to do this right.
Old May 10, 2002 | 07:30 AM
BigZ88's Avatar
Default Re: Brakes or struts? (BigZ88)
why are my posts so invisible?!?! jeeze
ttt
Old May 10, 2002 | 07:46 AM
94CivicSi's Avatar
For the size and weight of a Civic, stock brake sizes are adequate. Invest in a set of good quality pad and you'll be fine. Stock shocks on the other hand are trash. Dump 'em, now.
Old May 10, 2002 | 07:47 AM
DevinW's Avatar
personally I would go for the struts and then the big brakes. Stock shocks with a drop tend to get bouncy and 'it ain't cool.'
Old May 10, 2002 | 07:49 AM
DevinW's Avatar
..and you can always put integra brakes on your car....find a junked one and buy the suspension off of it. My car came equipped with that setup when I bought it
Old May 10, 2002 | 10:08 AM
BigZ88's Avatar
Default Re: Brakes or struts? (DevinW)
Ok, well i guess my next investment will be a set of AGX's or Illumas. Any suggestions? I will probably upgrade my brakes later perhaps after the swap if they seem bad. I will however probably get a set of better pads. Perhaps some that dont produce so dang much brake dust. Anyone here like EBC's or AEM's?
Old May 10, 2002 | 10:16 AM
94CivicSi's Avatar
AGX's
Illumas
EBC's
AEM's
Old May 10, 2002 | 10:17 AM
BROOD's Avatar
Between AGX's and Illuminas......go with the AGX's definetly, or better yet Koni yellows.
If you are set on larger brakes, get them after the engine swap. Just use some good pads for now. I usually use HAWKs. I've never used EBC or AEM.
Old May 10, 2002 | 10:26 AM
BigZ88's Avatar
Default Re: Brakes or struts? (SLPR)
I'd like koni yellows, but they are a bit pricey and im not going for extreme handling here....just enough to get me by when needed . So why AGX over Illumas? I thought Tokico was right up there tho...hrmm
Old May 10, 2002 | 10:28 AM
Kalokohan's Avatar
New User
Go with shocks and struts first and foremost because your stocks are probably taking a kunta kinte beating with the GC coils. You can still stop with stock brakes after a swap.
Old May 10, 2002 | 11:58 AM
spoonek4's Avatar
Good idea.
I will also get the KYB AGX since it's the best bang for the buck. Or Bilstein if I just want dampers instead of real coilovers.
Brakes wise. Depends on what engine u gonna swap in, and how u gonna drive ur car. For more info u can PM me or email me at spoonek4@hotmail.com
Old May 10, 2002 | 12:32 PM
94CivicSi's Avatar
It was less than 6 months before I blew my first Tok. Within 10 months, they were all shot. For $10 more each, the AGX's give you more performance, adjustability and build quality that has taken the abuse of NYC "roads" for over 18 months now without a problem.
Old May 10, 2002 | 07:43 PM
BigZ88's Avatar
Default Re: Brakes or struts? (94CivicSi)
Ok, guess i'll definately go for the AGX's then. thanks for the info guys.
Sleepy_Red_hatch
61
Aug 14, 2005 06:02 PM
Race Egr
Mar 26, 2005 03:43 PM
m0dr0cker
Oct 8, 2003 10:34 PM
Acura_I-RS
Sep 29, 2003 03:16 PM
DutchITR1689
Jul 2, 2001 07:39 AM
