I searched, but I wonder if anyone else has this issue with their G3.
Old Dec 3, 2006 | 09:43 AM
ShinsenTuner's Avatar
No Jodas
Default I searched, but I wonder if anyone else has this issue with their G3.
Alright. I drive a 2000 Integra, DB7. But getting to the point rather quickly, my Climate Control is weird. Does anyone else have a problem pushing the "heater/ac" lever from Blue to Red? Like as if theres something in the way or it just doesn't want to give. Sometimes when I try pushing it so I can have heat, it feels like if i push any harder it'll break and then it'll stay at "red" for a little then slowly push back to the interval between red/blue... does anyone else have this problem besides me and some other teggy owners? is there a fix for it?
Old Dec 3, 2006 | 09:58 AM
lVlemphizStylez's Avatar
Default Re: I searched, but I wonder if anyone else has this issue with their G3. (ShinsenTuner)
go under the hood...look at the switch by the heater hose...there is a metal strip that sits on like a stub...see what you can do so it has more play in it
Old Dec 3, 2006 | 10:08 AM
00integrals's Avatar
The problem is the cable that is connected to the lever under the dash. It needs to be pushed back into the holder. It can be a lil bit of a hassle at times.
Old Dec 3, 2006 | 10:14 AM
No Jodas
So there is a fix for this correct? Because I really am not looking forward to taking apart my dash.
Old Dec 3, 2006 | 10:36 AM
JDM_DC4_Fanatic's Avatar
have you done anything under the dash or hood latly? Our climate controls are all manual, so there are cables that move the flaps to divert the air through the right ducts. If you have done something recently, there could be something pushing/pulling or otherwise stressing the cables, which can make it hard to move. I doubt that the cabel has broken off, because when that happens, it is usuially very easy to move the slider, and the temp stays the same.
Old Dec 3, 2006 | 12:03 PM
Default Re: I searched, but I wonder if anyone else has this issue with their G3. (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">have you done anything under the dash or hood latly? Our climate controls are all manual, so there are cables that move the flaps to divert the air through the right ducts. If you have done something recently, there could be something pushing/pulling or otherwise stressing the cables, which can make it hard to move. I doubt that the cabel has broken off, because when that happens, it is usuially very easy to move the slider, and the temp stays the same.</TD></TR></TABLE>
I wasn't saying that it was broken ... I'm simply stating that the cable has somehow made it's way out of the holder. This exact same thing happened on my teg. The fix action is to push the cable back into the holder. It is a pain in the *** to do ... but that is the only way to fix it.
Old Dec 3, 2006 | 12:19 PM
No Jodas
The most recent thing i've done under the hood was the installation of my power wire cable for my amplifier. I haven't done anything much more than that and replacing the battery. The controls have always felt this way though, which I find weird.
Old Dec 3, 2006 | 03:47 PM
DELPHI's Avatar
I have a 94 db7 and got the exact same problom, I am stuck somewhere in the middle and going from one side to the other is a real pain and if I pushed it all the way to blue or red it would probobly break.
I'm going to tear mine out and my first suspect is going to be the retaining clip that holds the cable in place. I would be willing to bet you got the same problem.
Old Dec 3, 2006 | 04:10 PM
blkacgsr's Avatar
Default Re: I searched, but I wonder if anyone else has this issue with their G3. (DELPHI)
i have a 95 DC2 and i actually broke mine trying to change from hot to cold.
Old Dec 3, 2006 | 08:26 PM
JasonST's Avatar
Default Re: I searched, but I wonder if anyone else has this issue with their G3. (blkacgsr)
mines got the same problem, really hard to turn fully left or right, can't even turn it all the way to the cold side or i feel it's ganna break.
Old Dec 4, 2006 | 05:19 PM
CJ_2Dr's Avatar
same thing was with my 94 rs it went if i pushed it but it was hard like something was in the way, to damn bad i crashed the car.
Old Dec 4, 2006 | 07:00 PM
bluteggy00's Avatar
Default Re: (redDCcoupe)
Same exact problem with my 2000 ls goes all the way cold with some force but not all the way on the red.
Old Dec 4, 2006 | 07:28 PM
No Jodas
alright... this seems to have the same type of issues like how 6th Gen civics have tricky windows and faulty airbags. Does anyone know of a possible recall for these things?
Old Dec 4, 2006 | 07:34 PM
aaronISthrowed's Avatar
Default Re: (ShinsenTuner)
Mine does the same thing.
Old Dec 6, 2006 | 08:03 AM
vladd's Avatar
Default Re: I searched, but I wonder if anyone else has this issue with their G3. (00integrals)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00integrals &raquo;</TD></TR><TR><TD CLASS="quote">
I wasn't saying that it was broken ... I'm simply stating that the cable has somehow made it's way out of the holder. This exact same thing happened on my teg. The fix action is to push the cable back into the holder. It is a pain in the *** to do ... but that is the only way to fix it.</TD></TR></TABLE>
its pretty hard to push on both of my integras, and neither of the cables have popped out. i think that's just how they're made.
Old Dec 6, 2006 | 10:40 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
No, actually all the controls are electronic w/ servo motors operating the air flow dampers. The only thing mechanical is the temperature slider, which has a cable running to the heater core.
Mine is fairly easy to slide back and forth, with maybe only a little resistance. Check under the dash to make sure the cable isn't kinked or binding somewhere. If you stick your head under the passenger side dash, you should be able to see where the cable connects. Just move the temp. slider and see what moves under the dash, it shouldn't be hard to see.
soundquest
Honda Civic (2001 - 2005)
Jun 3, 2011 12:32 AM
myguitar
Mar 1, 2009 07:15 PM
PaulPark
Oct 27, 2007 06:52 PM
TheShodan
Oct 3, 2005 11:11 AM
AIWFCIATR
Oct 24, 2004 05:45 AM
