b16a2??
Old Dec 3, 2006 | 09:02 AM
-HONDA-'s Avatar
Default b16a2??
okay guys i need the wire colors \etc... for all the sensors that are on a Obd1 V tec harness/Civic CX harness 1992, long story short!
^i had a B16a2 in my car and took it out too put LS in cuz i thought it was going too be better and Ahhhhhh No it wasnt so i put my B16 back in my car and now my car feels sooooooo much weaker than before and my speedometer doesnt work and my engine light pops up showing code 17 ( which is my VSS) and the VSS is plugged in soo????? dont know whats up with that! anyways my car runs like **** putters is weak LMK what you guys think i should try to do that might fix it!?, also my Vtec doesnt even work when my engine light is off, thanks Guys for looking and reading. Can my ecu be bad somehow? someone link me too a site that might help me thanks!
heres what i got!
1992 obd1 EG hatch
B16a2
Obd2 dizzy ( Same dizzy as before)
and stock Civic harness CX wired for vtec etc.....
P30 ecu?
Another ?, is if my ECU was fried/BAD!, how would i know!, will my engine be able too start still if it was bad? would my car do certain things? cuz it reves up all the way still but i think it might be my ECU LMK.
Old Dec 4, 2006 | 04:15 PM
JasonST's Avatar
Default Re: b16a2?? (-HONDA-)
Vtec isn't engaging cause the speedometer isn't working, and if the ecu isn't getting a speed reading then it won't let Vtec engage, so get ur speedo working and ur vtec should work again. If ur vss is plugged in and it's still giving u the code then I'd probly replace it, should be fairly cheap to replace. Or at least do a search to see if theres a way to fix it without buying a new one.
xChrizcrozzx
Oct 17, 2014 03:53 PM
magefa
10
Jun 9, 2008 02:15 PM
-HONDA-
Dec 4, 2006 07:00 AM
-HONDA-
Dec 3, 2006 07:49 AM
