2003 Accord EX having issues with air flow direction
Old Dec 2, 2006 | 03:49 PM
skhodab's Avatar
Default 2003 Accord EX having issues with air flow direction
It seems that no matter what setting I have on the airflow, its always blowing out towards the face. Is there a simple way to fix this or is this a serious problem that needs maintenance. Normally I would go straight to the mechanic with this, but I had problems with the radio security before and that was a simple fix.
Old Dec 2, 2006 | 05:13 PM
badazzfocker's Avatar
Default Re: 2003 Accord EX having issues with air flow direction (skhodab)
Old Dec 3, 2006 | 08:14 AM
msedacca's Avatar
You mean like when you turn the dial all the way off and there is still some air blowing out? Same thing happens to me. Or do you mean your moving the air vents around and the air is still coming out in the same direction? Im confused.
Old Dec 3, 2006 | 08:47 AM
skhodab's Avatar
Default Re: 2003 Accord EX having issues with air flow direction (msedacca)
what i meant was that when i change airflow direction to feet or windshield, it keeps blowing at the face. point is that no matter what setting i have it on, it will only blow out in one direction.
Old Dec 3, 2006 | 12:11 PM
iam7head's Avatar
did it make a noise when you click on different setting? I know the newer heater/ac unit is electronic and there's no cable to turn.
most of the time, the computer took a crap and will not make a response.
Old Dec 3, 2006 | 12:12 PM
iam7head's Avatar
Default Re: 2003 Accord EX having issues with air flow direction (badazzfocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badazzfocker &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
hey arsewipe, do you have anything meaningful to say?
giving a blow-job face responses is all you could do?
Old Dec 3, 2006 | 07:45 PM
skhodab's Avatar
Default Re: 2003 Accord EX having issues with air flow direction (iam7head)
no, there's no sound when i click on it. any ideas what i should do?
Old Dec 4, 2006 | 06:07 AM
msedacca's Avatar
you can take it to the dealership and they can hook it up and it'll throw a code, but they'll charge you for that. Some places will let you hook it up and get the code for free.
Old Dec 4, 2006 | 08:02 PM
skhodab's Avatar
Old Dec 5, 2006 | 08:26 PM
skhodab's Avatar
Old Dec 7, 2006 | 08:14 AM
skhodab's Avatar
Old Dec 7, 2006 | 12:59 PM
H2290's Avatar
No matter what setting you have it on the left front driver's vent will blow. Are the other upper vents blowing all the time on every setting. If so then it is broke. If not then it is normal, just shut the vent.
bobcov
Jul 29, 2020 05:49 PM
webbie0012
Aug 19, 2017 03:43 PM
purplemoon16
Apr 30, 2013 03:39 PM
turrismaldon
Jun 25, 2002 09:08 AM
