BLOWN HEAD GASKET YES OR NO
Old Dec 1, 2006 | 08:28 PM
JWHATCH23's Avatar
Default BLOWN HEAD GASKET YES OR NO
WELL MY FULL TURBO KIT JUST CAME IN AND WELL I WAS JUST CHECKING ON STUFF ON MY CAR AND IT LOOKED LIKE MUDD WAS IN MY RADIATOR SO I ASKED A MECHANIC AND HE SAID IT COULD PROBABLE BE BLOWN HEAD GASKET AND OIL IS GETTING IN THE RADIATOR AND MAKING THAT MUDD TYPE EFFECT MY CAR IS NOT OVERHEATING THOUGH AND NOTHING IS COMING OUT FROM AROUND THE VALVE COVER DAMN I HOPING TO PUT ON THE TURBO THIS WEEKEND BUT **** reply please and yes i know it was in capslock but i am to lazy to erase it
Old Dec 1, 2006 | 08:31 PM
Deluzional's Avatar
Default Re: BLOWN HEAD GASKET YES OR NO (JWHATCH23)
do a compression test..usually when you get a blown headgasket, your oil would look milky, and your temp would shoot up instantly
Old Dec 1, 2006 | 08:34 PM
GserpleaSR's Avatar
go to a shop with a smog machine and tell them to check for blow head gasket at the radiator.
Old Dec 2, 2006 | 10:05 AM
jdm stefan's Avatar
Old Dec 2, 2006 | 02:11 PM
JWHATCH23's Avatar
(READ)
Old Dec 2, 2006 | 03:27 PM
jikespingleton's Avatar
are u over heating? wat are ur oil levels at? muddy oil is also known milk shake oil. stuff is nasty. if u have oil in ur radiator that ur head gasket is blown. you should replace ur radiator and head gasket asap. also milk shake oil usually will not drain out of ur oil pan. so if ur milk shake oil is severe then ull have to replace ur oil pan also.. but thats only in severe cases.
Old Dec 2, 2006 | 09:52 PM
shockerls's Avatar
Default Re: BLOWN HEAD GASKET YES OR NO (jikespingleton)
yeah my car had oil coming from what looked like the head, but if you traced the oil back it came to the cam seals(which i hear are notorious for leaking). i thought it was a head gasket on my car.... not sure if thats your case...
Old Dec 2, 2006 | 10:00 PM
90Integra_Rs's Avatar
Default Re: BLOWN HEAD GASKET YES OR NO (shockerls)
Change the oil if its milky the headgasket is blown.
Old Dec 2, 2006 | 10:05 PM
Default Re: BLOWN HEAD GASKET YES OR NO (90Integra_Rs)
Also your are right, on the B series motor the cam seal is notorious for leaking. Sometimes you find that they leak alittle around the dizzy and the vtec soleniod too. If it is the head gasket, you might want to put in new headstuds when you buy the new gasket. What motor is it?
Old Dec 3, 2006 | 01:31 PM
JWHATCH23's Avatar
B18B it doesnt overheat and the oil looks like oil not milky but the thing that i saw was like a green color algae or something not much but just a lil bit and its not leaking out coolant i never have to refill it so its not burning coolant
Old Dec 3, 2006 | 05:52 PM
Savannahdc2's Avatar
Is the car smoking? My car is losing oil some where i think its the oil pan gasket (which i just changed last week). But to the best of my knowledge if its the head gasket it will smoke and if u take off your oil cap it will have a white milkey substance under it
Old Dec 3, 2006 | 06:00 PM
Default Re: BLOWN HEAD GASKET YES OR NO (Savannahdc2)
also try to watch th amount of oil it uses.
Azimmer
24
May 9, 2012 02:34 PM
silent702
Feb 9, 2010 08:22 AM
apeek
Jan 23, 2008 07:28 PM
geldingmakr
16
Aug 4, 2004 01:28 PM
