Noisy Slave Cylinder?
My car makes a loud noise every time I let out my clutch when in neutral and when I am driving it gets loud at about 3k in first and 2nd gear.. It's really loud. I was told if I bled my slave cylinder it would stop it. I bled it today and refilled my clutch fluid. It did nothing.. What could it be, the slave cylinder or what. Can anybody help me?
Iono what it is, your descriptive skills suck ***. I can tell you it DOES NOT sound like the slave cylinder in any way, shape, or form.
You said the loud noise only happens when you let out the clutch. Then you go further to explain how when your RPM's go up it gets louder... So by the way you're explaining it the only way it's possible is if you pump the clutch while you're driving.
Please explain it better if you want help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Iono what it is, your descriptive skills suck ***. I can tell you it DOES NOT sound like the slave cylinder in any way, shape, or form.
Please explain it better if you want help.</TD></TR></TABLE>
It only happens when the clutch is not engaged. I am not sure how to describe the sound, the sound is much louder than sound comming from my engine it sounds like a loud distorted sound. if that makes much sense..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch »</TD></TR><TR><TD CLASS="quote">My car makes a loud noise every time I let out my clutch when in neutral</TD></TR></TABLE>
I mean't that I'm not driving the car I am parked and this is happening while the car is running while pushing the clutch in and letting it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch »</TD></TR><TR><TD CLASS="quote">and when I am driving it gets loud at about 3k in first and 2nd gear.. It's really loud.</TD></TR></TABLE>
I mean't not by pumping the clutch when driving, it just starts getting loud while I get up to speed.
xsnrgsr
Jul 13, 2003 08:23 PM
