header for d16y7 need help/advice
Old Dec 1, 2006 | 05:33 AM
cwf1988's Avatar
Default header for d16y7 need help/advice
friend has the same motor as me a d16y7 non vtec, we got a header that will bolt on to his stock piping, being obd2 it has two o2 censers,, one in the stock manifold and one right below the cat. on the stock manifold the cat it hook with the manifold then goes into the down pipe. the question is how exactly will i put the header on, i mean the header has a place for the 2 o2 censors but what about my cat, will i pass smog, and will i throw any codes. sorry if im just stupid i just want to do this right before running into pro,, thanks
Old Dec 1, 2006 | 05:51 AM
cwf1988's Avatar
Default Re: header for d16y7 need help/advice (cwf1988)
BUMP
Old Dec 1, 2006 | 05:57 AM
cwf1988's Avatar
HELP MAYBE !!!!!
Old Dec 1, 2006 | 06:24 AM
hondamark35's Avatar
not sure if you would pass smog. you won't throw a code if you leave the secondary O2 plugged in and drape it over the trans or tie it off out of the way somewhere. the only time i get a code is if i floor it below 2000 rpm (which is pointless anyway)
you're other option is to swap your b-pipe for an EX b-pipe and cat. then have a muffler shop weld in another O2 bung. that way you should pass smog.
Old Dec 1, 2006 | 06:47 AM
cwf1988's Avatar
Default Re: header for d16y7 need help/advice (hondamark35)
thanks man, why do u throw a code under 2k,,, does it come on and go off,, the second o2 is right under the cat and is hooked on a clip for it doesnt drag,,
Old Dec 1, 2006 | 06:53 AM
cwf1988's Avatar
anybody else???????
Old Dec 1, 2006 | 10:07 AM
cwf1988's Avatar
bump
Old Dec 1, 2006 | 10:08 AM
cwf1988's Avatar
BUMP help pleaz
Old Dec 1, 2006 | 10:11 AM
chrisw85's Avatar
you wont pass smog without a cat in there. tabby cats are nice.
anyway. like mark35 said so long as you retain the before and after cat o2 sensors and put in an OBDII cat you sould be ok.
Old Dec 1, 2006 | 10:14 AM
cwf1988's Avatar
Default Re: (chrisw85)
can i use the header ( which i plan on) and get a ex down pipe with the cat and hook up the o2 sensor like the ex model would
Old Dec 1, 2006 | 10:31 AM
cwf1988's Avatar
Default Re: (cwf1988)
dump damit
Old Dec 1, 2006 | 10:38 AM
Ricey McRicerton's Avatar
I'm a little confused as to what you're saying, but just setting an 02 sensor out in the open WILL NOT keep you without a CEL long term. You'll need either an 02 simulator or to get a cat in there.
Old Dec 1, 2006 | 10:47 AM
cwf1988's Avatar
Default Re: (Ricey McRicerton)
^^^^ my stock manifold has a cat hooked to it before it goes into a down pipe,, i was wondering can i put the after maket headers on and get a ex downpipe with the cat afrter the downpipe,, the o2 sencers will hook to the header
Old Dec 1, 2006 | 11:38 AM
cwf1988's Avatar
over 60 views and no answer,, bump!!!!!!!
Old Dec 1, 2006 | 11:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwf1988 &raquo;</TD></TR><TR><TD CLASS="quote">^^^^ my stock manifold has a cat hooked to it before it goes into a down pipe,, i was wondering can i put the after maket headers on and get a ex downpipe with the cat afrter the downpipe,, the o2 sencers will hook to the header</TD></TR></TABLE>
You can put aftermarket headers on a Y7. You can add a cat downstream. You'll still need one sensor in the header and one senor downstream of the cat. I never relocated mine, so I don't know if you'll have to extend wires, but I imagine you will.
Basically you're going from Stock to aftermarket. The red lines are 02 sensor locations. I'm still not really understanding your question so I hope this helps. The big blobs are catalytic converters. Nobody say a word about my sweet *** MSPaint skills either.
Old Dec 1, 2006 | 11:47 AM
Archidictus's Avatar
Unceasing Measure
^^^LOL
Old Dec 1, 2006 | 11:52 AM
cwf1988's Avatar
Default Re: (Archidictus)
yes i want to put the after market header on,, but the stock one is hooked directly to the cat before it gets to the downpipe,, what do i do with a cat and where the o2 will go
Old Dec 1, 2006 | 11:55 AM
chrisw85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwf1988 &raquo;</TD></TR><TR><TD CLASS="quote">yes i want to put the after market header on,, but the stock one is hooked directly to the cat before it gets to the downpipe,, what do i do with a cat and where the o2 will go</TD></TR></TABLE>
umm look at the pic above?
obviously you can no longer utilize the stock cat if you put the aftermarket header on, you get a different cat...
aftermarket header will either have an o2 bung on one of the primaries or on the collector, and the secondary o2 sensor needs to be plugged in after the new cat.
Old Dec 1, 2006 | 12:05 PM
Do you have eyes, I even drew a picture? You have to get an aftermarket cat, put it after the header, and have an 02 bung welded onto the piping either at the cat or just downstream of it.
Old Dec 1, 2006 | 12:27 PM
robert_v's Avatar
guranteed to fail smog with out a catalytic converter,
to run without no o2 is going to cause check engine light,
to convert it you will need an ex or si catalytic converter and a new mid pipe, then extend your o2 sensor wire. secondary o2 should be placed in the same area as originally designed, in the catalytic converter, while the first one is in front of the catalytic converter. just as Ricey McRicerton
drew in the upper response
Old Dec 1, 2006 | 01:36 PM
sdaudiogod's Avatar
you need to put an aftermarket header for a 96-98 ex (or any d with 2 o2's) a ex cat will bolt on just after the header then you can add an ex exaust or an aftermarked exaust for an ex
or just swap the whole ex exaust system
with two o2 holes all you need to do is to extend the o2 wiring to reach... nsolder and heatshrink tubing is better than crimps
Old Dec 1, 2006 | 02:41 PM
tha_badguy's Avatar
most respectable header brands come with the o2 extension
& that pic got it right besides the o2 placement
most aftermarket headers have the primary 02 in the collector just b4 the flange
& the secondary o2 is in the cat on obd2 cars
so just buy a header
& an obd2 cat
Old Dec 1, 2006 | 02:53 PM
chrisw85's Avatar
to extend the wiring on my 94 civic i just cut the split loom and pulled out the wires and re-taped. worked like a charm. Also, the NTK 4-wire direct plug in for hondas part #24172 O2 sensor has a longer cable than most. Works perfect for my 94 civic.
Old Dec 1, 2006 | 03:19 PM
Aquafina's Avatar
All I did was get the correct gauge wire and shrink connectors and extend the harness. No pics of it uploaded.
ManitobaCivicDX
25
Jun 18, 2012 11:06 PM
94trouble
Dec 10, 2010 08:03 PM
spray_bombed
Feb 18, 2008 03:02 PM
jdmOPTION2
Apr 24, 2007 10:49 AM
spog
Oct 18, 2004 01:38 PM
