crankshaft pulley spins freely
I just picked up a low miles B16A3 block and noticed the crankshaft pulley is spinning freely. I put my hand behind the pulley and the keyway does not feel chipped as far as I can tell.
Is there anyway I can check before removing the pulley?
Should I replace #15 and #16 along with the key?
if it just spins freely , and the bolt is tight , thats no good , lol. might have just sheared the keyway , hopefully. use a chain wrench to hold the pully and take the nut off. than youl see whats going on. if the timing gear itself is broken up , than youl need part #15.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_vtec »</TD></TR><TR><TD CLASS="quote">I hope it is only the key and not a chipped crank keyway.. There is no way to tell without removing the crank pulley?
Nada, g2 pull it.
</TD></TR></TABLE>Nada, g2 pull it.
i told you how to pull it when you asked me dude , use a chain wrench(over top of a piece of belt or somin so not to damage pully if i didnt mention that before) it will work fine.
just get an impact and a 19 and take the damn bolt out! it wont hurt nothing!
if you really wanted to know you would have done that by now!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rip94delsol »</TD></TR><TR><TD CLASS="quote">just get an impact and a 19 and take the damn bolt out! it wont hurt nothing!
if you really wanted to know you would have done that by now!</TD></TR></TABLE>
Won't matter if he can't hold it still.
AT OP:
Jam it up, there's tons of ways.
AT OP:
lol, i'm working on it.. I have no impact gun and the block is in my apartment (2nd floor)
it would be a serious pain in the *** to carry it down stairs, drive it to a shop, and then back up the stairs just to remove a bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR »</TD></TR><TR><TD CLASS="quote">put a flywheel on and hold it from there.</TD></TR></TABLE>
I guess this is my only option, thanks
