b20 vtec or ls/vtec
Old Nov 30, 2006 | 07:13 PM
slickshifter's Avatar
Default b20 vtec or ls/vtec
How much would it cost to have this done? Is it any cheaper than a b16a2 swap? Thanks for your input in advance.
Old Nov 30, 2006 | 07:20 PM
yeahme17's Avatar
Default Re: b20 vtec or ls/vtec (slickshifter)
no way its cheaper it is hard to build a good ls/vtec because the ls block was never made to turn those RPM's. it can be done with a build block but it would not be cheaper then a b16a motor
Old Nov 30, 2006 | 07:44 PM
deadline's Avatar
B16 then save some money later for a turbo..
Old Nov 30, 2006 | 07:47 PM
eg_civic209's Avatar
Default Re:
id say b20/vtec
Old Nov 30, 2006 | 07:59 PM
doood's Avatar
been there done that
Default Re: Re: (eg_civic209)
a properly built lsvtec or b20vtec is going to cost a good bit more than a b16 swap
Old Nov 30, 2006 | 08:00 PM
Syndacate's Avatar
LS blocks and B20 blocks are the same asside from the displacment. Same material, same thickness.
In case anybody's wondering why I'm saying this is b/c sooner or later somebody's gonna post "LS/VTEC, because the B20 has thin cylinder walls" or some stupid tool remark like that....
Old Nov 30, 2006 | 08:08 PM
slowassd16y8's Avatar
Default Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">B16 then save some money later for a turbo..</TD></TR></TABLE>
Old Nov 30, 2006 | 08:11 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slickshifter &raquo;</TD></TR><TR><TD CLASS="quote">How much would it cost to have this done? Is it any cheaper than a b16a2 swap? Thanks for your input in advance.</TD></TR></TABLE>
To do it, or to do it correctly? Unfortunately the long stroke of the LS block was not designed for 8200rpms, so if you're going to do it, you need to make the block capable of not wanting to kill itself at those RPMs.
Old Nov 30, 2006 | 08:17 PM
doood's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">LS blocks and B20 blocks are the same asside from the displacment. Same material, same thickness.
In case anybody's wondering why I'm saying this is b/c sooner or later somebody's gonna post "LS/VTEC, because the B20 has thin cylinder walls" or some stupid tool remark like that....</TD></TR></TABLE>
b20's have a mono-sleeve design different from other b blocks
prjdmek
Mar 10, 2010 09:24 AM
bui1528
Aug 27, 2009 12:24 PM
VtecHusker
10
Jul 30, 2007 11:47 PM
twotimesfour
Nov 11, 2002 05:26 PM
CRXSleeper
18
Jul 23, 2002 02:54 PM
