Clutch Cable???
Old May 9, 2002 | 07:25 PM
CrxSi10's Avatar
Default Clutch Cable???
I have a b18c with a 92 GSR tranny into my 91 CRX si. Is it just me or do I have to use a different clutch cable other then the 91 Integra LS? You see, I put that on and it seems to be alittle short and it doesn't fit right going into the firewall. What am I doing wrong guys?
Have anybody used the new Hasport billet mounts? It seems like my b18c is way too high and I think cutting the hood support will not work or will it?
For all those who know, will the alternator plug from the CRX work the same way as the obd1 plug. In other words, can I use the stock CRX plug to run the obd1 alternator?
thanks
Need help a.s.a.p., my car has been sitting for 2 months now and would like it up an running soon.
Old May 9, 2002 | 08:46 PM
juicy.koreans.suck's Avatar
Default Re: Clutch Cable??? (CrxSi10)
1. you need to hook it up at the pedal first, then the tranny.
2. i got the billet jammys. i love the way it sits. i needed no adjustment at all.(2nd gen b16a/93 gsr trans(ys1))
3. yes, use your si wiring harness. i changed over the injectors and the distributor and ran the pr3. i love my ******* car.
[Modified by 88'CRIX, 5:46 AM 5/10/2002]
J2turbo21
Jun 27, 2002 05:07 AM
VTECVillain
May 13, 2002 07:54 AM
VTECVillain
May 13, 2002 07:47 AM
VTECVillain
May 12, 2002 04:39 PM
CrxSi10
May 10, 2002 07:16 AM
