check engine light came on
Old Nov 30, 2006 | 05:17 PM
farhan445's Avatar
Default check engine light came on
i was driving home and the check engine light came on 5minutes before i got home.. as most of u alrdy know i had a spon bearing which i fixed but my crankshaft is still fuked (makes knocking sound) anyways the check engine light came on. its too dark out and raining so i just thought i come here and post lol
what are the possible causes?? i was thinking sensors?? should i try disconnecting the battery for a few minutes then connecting it back?
Old Nov 30, 2006 | 05:32 PM
asdfsad's Avatar
Default Re: check engine light came on (farhan445)
get the code, no one can give you input w.o it.
Old Nov 30, 2006 | 05:38 PM
94Vtecluder's Avatar
Default Re: check engine light came on (asdfsad)
Gee maybe your UNBALANCED crankshaft is finally ripping apart your block. Just a gues....
Old Nov 30, 2006 | 06:54 PM
M2B4's Avatar
Default Re: check engine light came on (94Vtecluder)
sensors heh......
ur asking us to flash ur code for you kinda hard when were on the other side of the computer....go flash it and tell us the number.
Old Dec 1, 2006 | 05:44 AM
AZprelude's Avatar
got to your local AUTOZONE and run their diagnostic tool through your car. you'll most likely get a p code. its a free service, i'll specify whats wrong with your car.
Old Dec 1, 2006 | 05:46 AM
98vtec's Avatar
moderator emeritus
Default Re: (AZprelude)
needle in a haystack
Old Dec 1, 2006 | 11:28 AM
00Luder's Avatar
yeah just go up to Autozone and get then to check what code(s) its throwin. I went to Autozone but they could not read my code because its a obd1. I have a 93 JDM H22. my CEL comes on sometimes. usually usually if im just cruzing around in low rpms. I recently changed my distribor, new spark plugs and msd wires, and got a new fuel filter. But light still comes on. i'll try to get the code myself via paperclip i just havent got around to it yet.
Old Dec 1, 2006 | 12:00 PM
farhan445's Avatar
Default Re: check engine light came on (92Luder)
WHAT THE F**K I TURN IT ON THIS MORNING AND THE LIGHT NEVER CAME ON AT ALL. DROVE IT AROUND AND ITS FINE.. oops sry about capitals .. nothing wrong with it and the engine light is off now..
Old Dec 1, 2006 | 12:51 PM
JDMhondalude22's Avatar
itll come back on, dont worry.
Old Dec 3, 2006 | 03:33 PM
farhan445's Avatar
Default Re: check engine light came on (JDMhondalude22)
couple days passed, still hasnt came on :D
Old Dec 3, 2006 | 06:52 PM
1GPlusSH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farhan445 &raquo;</TD></TR><TR><TD CLASS="quote">WHAT THE F**K I TURN IT ON THIS MORNING AND THE LIGHT NEVER CAME ON AT ALL. DROVE IT AROUND AND ITS FINE.. oops sry about capitals .. nothing wrong with it and the engine light is off now.. </TD></TR></TABLE>
Just out of curiousity, why would you apologize for something and still do it?
And...you don't have to unhook your battery cable to reset your engine codes. You can just take out the clock/radio fuse for a few seconds.
doja
Jan 22, 2011 08:38 PM
_uh_oh_
Honda Civic (2001 - 2005)
Mar 31, 2008 04:07 PM
oneforce
Mar 10, 2005 12:02 PM
importdude2000
Jul 17, 2004 12:53 PM
Revgasm
Nov 3, 2002 03:31 PM
