Transmission Problem on my Civic VX
Old Nov 30, 2006 | 04:57 PM
truevietluv636's Avatar
Default Transmission Problem on my Civic VX
i got a 92 civic vx, stock. no problems untill now.
here's the story.. i was driving up hill and stopped at a stop sign, when trying to put it into first gear it wouldnt go in, after trying it 3 more times it popped in... i was all happy then after half a block i hear a grinding sound, still in frist gear. i was like wtf, and then i tried shifting into second and it wouldnt go in, shoved the shifter into first and somehow i got home. looked at my tranny and nothing was wrong. afterwards test driving the car again the tranny seemed all fuked up. Sometimes first and second gear didnt go in and they keep grinding, the rest of the gears felt a little wierd... like they were about to pop out...
oh yeah, the wierdest ****, in first gear driving at 2500-3500 rpm a wired grinding sound, the same usual sound like in reverse...
could anyone give me some advice of what could be wrong.
Old Nov 30, 2006 | 06:00 PM
kaiba's Avatar
Default Re: Transmission Problem on my Civic VX (truevietluv636)
Seems like the fork broke. Time for new tranny.
I vote 96-00 EX.
Old Nov 30, 2006 | 07:15 PM
CapnKrunch's Avatar
Default Re: Transmission Problem on my Civic VX (kaiba)
I have a VX also. My stock transmissions fine and I'm looking to buy a Si/EX tranny for shorter gearing. VX tranny=horrible until you get on the highway.
Old Nov 30, 2006 | 07:47 PM
deadline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">Seems like the fork broke. Time for new tranny.
I vote 96-00 EX. </TD></TR></TABLE>
i'd say92-95 ex-si tranny's better
Old Nov 30, 2006 | 08:19 PM
kaiba's Avatar
Default Re: Transmission Problem on my Civic VX (deadline)
92-95 have alumiun fork.
96-00 have metal. Metal is stronger.
I'm sure the 92-95 and 96-00 have about the same gearing ratio.
Old Nov 30, 2006 | 08:33 PM
thank for the info. whats the average price for a ex or si tranny? the price range i might be able to get it for is like $200-300. is that too expensive?
Old Nov 30, 2006 | 08:40 PM
i was wondering if there was a way to pull out the tranny w/o having to pull out the whole engine out... or is it just easier pulling the engine out too... doing this in my home garage...
Old Nov 30, 2006 | 08:56 PM
crimsonv4mpire's Avatar
engine on a jack and block of wood. only takes a few hours with air tools &lt;axle nut&gt;
and pretty straight forward
Old Dec 1, 2006 | 09:33 AM
JShull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">92-95 have alumiun fork.
I'm sure the 92-95 and 96-00 have about the same gearing ratio.</TD></TR></TABLE>
Since when is aluminum not metal? (kidding with ya)
96-00 have steel forks, definately a plus.
Old Dec 1, 2006 | 11:52 AM
yengo's Avatar
Default Re: Transmission Problem on my Civic VX (JShull)
Y8 trannys have a slightly shorter 2nd gear than the ex/si trannys. aluminum forks are good and bad... bad cause they can break easier than steel forks... but good because having only the fork break can save other parts of the tranny...steel forks wont break as easy but might cause other parts to break easier. i personally would rather change out shifter forks than syncros and speed gears.
Old Dec 1, 2006 | 01:05 PM
Bense's Avatar
you speak what you have little clue about
Separker629
Jan 24, 2017 04:57 PM
Ned UK
15
May 25, 2005 04:59 AM
alexngo
Mar 25, 2004 03:34 PM
ImportsCRX
Mar 12, 2004 10:08 AM
pbcdb
Feb 20, 2004 04:21 PM
