Car won't turn on.. Help please
Old Nov 30, 2006 | 03:14 AM
gsrcivic619's Avatar
Default Car won't turn on.. Help please
So i was stopped at a red light and my car suddenly idled at a very low rpm, and suddenly turned off on me. I tried turning it back on and No go. It cranks and sounds like it's about to turn on, but never turns on. I tried pop starting it and all i can hear is the sound of the (i think it was the starter) starter spinning but nothing happens other than the spinning sound. I checked to see if the starter was loose, and it was fine. I have a 97 honda civic, Single cam motor (stock). I tried checking fuses, but i couldnt find anything that was blown. My friend thinks its the timing belt. The belt is really loose... When i try starting up the car... it cranks but the cam sprocket doesn't spin, it doesnt move at all. The only thing spinning on the timing belt is the bottom pulley. Can someone please give me some suggestions on what might make my car turn on>!? Thanks a lot guys. Brian.
Old Nov 30, 2006 | 04:25 AM
cwf1988's Avatar
Default Re: Car won't turn on.. Help please (gsrcivic619)
how many miles on the car????
Old Nov 30, 2006 | 11:04 AM
Default Re: Car won't turn on.. Help please (cwf1988)
The motor has about 90,000-100,000. it's a 99 motor.
Old Nov 30, 2006 | 11:24 AM
EFbomb's Avatar
Yah, sounds like your either siezed your cam, and sheared the keyway off the cam gear
or the timing belt broke.
either way, now that you've cranked your car over a few hundred times your screwed
Honda motors are intereference motors, meaning the top end (valves) can collide with the pistons if they are not kept in perfect time with the timing belt
long story short, look for a new motor
good luck
bump... someone please help...
Old Nov 30, 2006 | 11:26 AM
dam thanks for the info. so there's no way it could be something else?
Old Nov 30, 2006 | 11:30 AM
EFbomb's Avatar
If the crank is turning and the top end isnt, that is likley the problem.
You may have gotten really lucky and the valves might have been closed and might not have tagged a piston, but either way, you need to atleast pull the head off and take a closer look.
Or tow it to a shop, and have them look at it.
If its not worth your time just find a used motor locally for cheap, or just go all out and do a motor swap
Old Nov 30, 2006 | 11:47 AM
Default Re: (EFbomb)
do you think if i try and tighten up the timing belt, the cam might spin?
Old Nov 30, 2006 | 11:55 AM
Kamin's Avatar
Default Re: (gsrcivic619)
sounds like a broken timing belt if the crank is spinning but the cam is not. theres only 1 thing that connects them and thats the timing belt.
pray to god you didnt mash your valves. if you did, new engine time.
Old Nov 30, 2006 | 12:04 PM
nva2nd's Avatar
If the timing belt broken there no point in tighting it
shogun88
Feb 28, 2012 11:28 AM
Lao17
12
Aug 2, 2011 01:49 PM
green_si
18
Mar 3, 2010 03:24 PM
blakh
Nov 25, 2007 03:43 PM
Osek206
14
Jan 13, 2006 11:29 AM
