Torque specs on Eagle rods (upgraded bolts) D16
Old Nov 29, 2006 | 07:14 PM
TurboGoKart's Avatar
Default Torque specs on Eagle rods (upgraded bolts) D16
My engine just started knocking, and I'm in the process of taking things apart and making sure everything is kosher on the bottom end. I'm trying to find the torque specs for the Eagle rods with the upgraded rod bolts (I think they're 3/8"), or are the specs the same as I would find in my Haynes manual?
Engine is a D16Z6.
Old Nov 29, 2006 | 10:41 PM
HiProfile's Avatar
Default Re: Torque specs on Eagle rods (upgraded bolts) D16 (TurboGoKart)
IIRC, b18b stock specs are something like 24ft/lbs, and just found 5/16" arp rod bolts are supposed to be at 28ft/lbs. I wish I had the specs, but I got mine for cheap, slightly used & w/o spec sheet.
In for the answer too, although you may want to check turbod16.com or d-series.org
Old Nov 30, 2006 | 05:04 AM
Finland's Avatar
just a piece of advice: use a stretch gauge. ARP has a chart on their website for recommended bolt stretch. It's a lot more precise way of making sure you have the correct torque.
Old Nov 30, 2006 | 02:54 PM
Default Re: (Mr. Helsinki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Helsinki &raquo;</TD></TR><TR><TD CLASS="quote">just a piece of advice: use a stretch gauge. ARP has a chart on their website for recommended bolt stretch. It's a lot more precise way of making sure you have the correct torque.</TD></TR></TABLE>
That's great info. I just found that out earlier today. Thanks!
mafia
24
Sep 30, 2009 09:37 AM
andyrew500
Mar 4, 2006 02:53 AM
gunmetalcivic
May 4, 2004 03:12 AM
99B16Si
Nov 19, 2003 10:54 AM
S13 slide
Jan 8, 2002 09:29 AM
