removing cruise control actuator???
Old May 9, 2002 | 05:08 PM
GreenD's Avatar
Default removing cruise control actuator???
i got the remove the 3 bolts part, but what do i do with the cable tha goes into the firewall? i dont want to cut it or do anything permenent in case i ever return the car to stock to sell it.
tia
Old May 9, 2002 | 08:35 PM
GreenD's Avatar
Default Re: removing cruise control actuator??? (GreenDestiny)
Old May 10, 2002 | 12:18 AM
Unsung's Avatar
Good question. Anyone have an answer?
Old May 10, 2002 | 04:01 PM
GreenD's Avatar
Default Re: removing cruise control actuator??? (JDM B Series)
Old May 11, 2002 | 10:05 PM
GreenD's Avatar
one more time
Old May 11, 2002 | 11:37 PM
JV's Avatar
JV
Who?
Well on my 95 EX all i had to do was pull the cable out of the bracket on the top of the gas pedal...
Old May 12, 2002 | 07:13 AM
Bumnah's Avatar
Default Re: removing cruise control actuator??? (JV)
yup that's what i did. it's just hooked onto the gas pedal.
has anyone removed the control module in the driver side kick panel? i wanna remove that to, anything special i have to do to remove it?
let me know please.
Old Aug 4, 2004 | 11:27 AM
JBBNJ609's Avatar
Default Re: removing cruise control actuator??? (Bumnah)
bump because i still wanna know this , also will i get a check engine light because of no cruise control ? and if i get a cel can i turn it off ?? thanks
JAY
Old Aug 4, 2004 | 11:47 AM
ki3t's Avatar
This user can set his title.
Go underneath the dashboard and on the brake pedal the cable is there on some sort of pin that you have to pull out.
Walla and your done
Old Aug 4, 2004 | 02:42 PM
JBBNJ609's Avatar
Default Re: removing cruise control actuator??? (ki3t)
so no check engine light or the like ??
TheCivicMafia
Jun 14, 2012 01:55 PM
My_Teknique
19
May 2, 2010 09:46 PM
marcus81184
May 12, 2009 09:05 AM
sd_ej1
Dec 30, 2008 09:30 AM
Spade
Jul 5, 2002 02:18 PM
