Water and black gas from muffler
Old Nov 29, 2006 | 07:40 AM
k_lude's Avatar
Default Water and black gas from muffler
my lil brothers car has water and some black stuff coming out of his unbolted muffler so its just the piping at the end that connects to the muffler...is this a bad block or what might be the result of it?
Old Nov 29, 2006 | 08:05 AM
Neonxiii's Avatar
Default Re: Water and black gas from muffler (k_lude)
im pretty sure its oil... check for bad gaskets
Old Nov 29, 2006 | 08:15 AM
JTCdudeman's Avatar
Master H Technician
unburnt fuel.... Its just running rich... The black coloring is just carbon coming out with it.... This is quite common... And on a car with no muffler attached, its not suprising to see...
Old Nov 29, 2006 | 08:23 AM
nonvteclude's Avatar
Default Re: Water and black gas from muffler (JTCdudeman)
^^^x2 happens all the time with alot of cars
Old Nov 29, 2006 | 10:53 AM
LudaChris's Avatar
Default Re: Water and black gas from muffler (nonvteclude)
No worries, water coming out of muffler is normal, means your catalytic converter is still working. Black stuff is just carbon deposits.
Old Nov 29, 2006 | 05:00 PM
russlan44's Avatar
Default Re: Water and black gas from muffler (LudaChris)
same here its just running rich
Old Nov 29, 2006 | 06:46 PM
k_lude's Avatar
Default Re: Water and black gas from muffler (russlan44)
alright thanks guys...so hopefully its not the head gasket...
Old Nov 29, 2006 | 07:08 PM
russlan44's Avatar
if it was head gasket would the smoke be blue, correct me if im wrong
Old Nov 29, 2006 | 09:17 PM
LudaChris's Avatar
No, blue smoke indicates oil is getting into the cylinder and white smoke due to the coolant getting into the cylinder especially with open deck blocks. Blue smoke is possible too with blown head gasket since there is also oil passages, most likely on closed deck block.
mynameizstitch
Jul 1, 2009 10:24 PM
samdizzle562
Nov 22, 2007 11:46 PM
b18vtek
Apr 8, 2005 10:53 PM
NA JDM GSR
Feb 28, 2005 11:59 AM
SIK IN DA HED
Mar 25, 2004 11:32 AM
