CX and intermittent wipers
Old Nov 29, 2006 | 05:59 AM
jmeyer99's Avatar
Default CX and intermittent wipers
My CX does not have intermittent wipers, even though there is an intermittent wiper setting on the stock. Is this the way a CX should be?
Old Nov 29, 2006 | 06:11 AM
J98EX's Avatar
Default Re: CX and intermittent wipers (jmeyer99)
my CX has them
Old Nov 29, 2006 | 06:42 AM
Red North's Avatar
Mine were wired wrong when my swap was done, so they would only move really slow. I had to take it to Honda and get them to check it out.
Old Nov 29, 2006 | 09:25 AM
BlueIntegraBoy's Avatar
The EG CX/VX did not come with them, but can be added on easily with the ICU and the switch.
Old Nov 29, 2006 | 10:21 AM
kaiba's Avatar
Default Re: CX and intermittent wipers (BlueIntegraBoy)
I would like to know where ICU is located.
Old Nov 29, 2006 | 10:23 AM
Default Re: CX and intermittent wipers (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">I would like to know where ICU is located. </TD></TR></TABLE>
Behind the fusebox
Old Nov 29, 2006 | 10:26 AM
kaiba's Avatar
Damm... that where is was at. What does it look like.
Old Nov 29, 2006 | 10:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">Damm... that where is was at. What does it look like.</TD></TR></TABLE>
Large rectangular box. #18
Old Nov 29, 2006 | 10:47 AM
Relic1's Avatar
ICU - attached to rear of fuse box. can be a pain to remove unless you're flexable like gumby OR pull the fuse box down. (bottom right)
Old Nov 30, 2006 | 05:33 AM
kaiba's Avatar
Default Re: (Relic1)
Now for the CX and VX. Is the ICU just plug and play? I really hope so.
Old Nov 30, 2006 | 08:09 AM
Relic1's Avatar
yes, if you have the switch with the int setting
Old Nov 30, 2006 | 08:25 AM
kaiba's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">yes, if you have the switch with the int setting</TD></TR></TABLE>
Yeah, i got the switch. But at that time i didn't know where ICU was located. Now i just research 88-91 and 96-00 civic. They have different part# for ICU. Just by change will the 94-01 integra work.
Can't seem to find the teg part# to match with the civic.
Old Nov 30, 2006 | 09:35 AM
Relic1's Avatar
you lost me now. teg part#s? this is for your EG right? get an ICU out of an EX or DX that has int wipers.
I'm also working on a list of parts you have to add to the non-int wipers ICU to make it int capable. But at this point simply picking up one from an EX is easier.
Old Nov 30, 2006 | 10:21 AM
Default Re: (kaiba)
Teg ICU will work if you have teg switch (rear wiper).
Old Nov 30, 2006 | 10:24 AM
kaiba's Avatar
Default Re: (BlueIntegraBoy)
Okay, so teg ICU works. Just wanna make sure. Heading out to junk later after work. Hoping to find a 92-95 civic or 94-01 teg.
HickamHatch
Texas -OK -LA (Sales)
May 13, 2008 06:10 AM
FR Killah
Mar 19, 2005 08:58 PM
crackerjacker006
17
Jan 20, 2005 06:32 AM
OneFire
Feb 7, 2004 07:42 PM
sethm
57
Oct 6, 2003 07:10 AM
