Want new goodies but not sure
Old Nov 28, 2006 | 08:59 PM
downsouth0's Avatar
Default Want new goodies but not sure
Right now Im runnin a t3/t4 turbonetics/fmax turbo kit with a/c on my 95 gsr, and Im wanting to upgrade to a full 3" turboback exhaust. I am running slightly thicker aluminum dual core radiator and puller fans, and everything fits ok with nothing touching nothing. Now this may sound stupid but, are there manifold/3"Dp combinations that will fit my application, or would I have to switch everything around to make it fit? thanx in advance.
Old Nov 28, 2006 | 09:22 PM
TurboedDC's Avatar
Default Re: Want new goodies but not sure (downsouth0)
they shouldnt come with the manifold. one problem you may find is with your ac.; you may not be able to fit the 3" dp through. Your best bet is to get a custom dp and exhauts made.
Old Nov 28, 2006 | 09:35 PM
downsouth0's Avatar
Default Re: Want new goodies but not sure (TurboedDC)
I was thinking maybe a 2.5" dp flared to 3" would fit, but like you said it would have to be custom.
Old Nov 29, 2006 | 05:17 AM
b18sihatch's Avatar
that will choke off power if you do that, you might as well run 2.5turbo back.
think about it the turbo is only going to be able to push the air out of the 2.5 tubing yes it gets bigger, however it would be best to just get 3'' downpipe or 2.5 all the way back
Old Nov 29, 2006 | 05:41 AM
BoostedEG6's Avatar
Default Re: Want new goodies but not sure (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">that will choke off power if you do that, you might as well run 2.5turbo back.
think about it the turbo is only going to be able to push the air out of the 2.5 tubing yes it gets bigger, however it would be best to just get 3'' downpipe or 2.5 all the way back</TD></TR></TABLE>
Not always true..... most of the time when you flare out the down pipe from a 2.5 to a 3" you will see a slight power increase... You will not "choke" off power by having a bigger exhaust
Thats like telling me that my setup is choking because I have a 3" flared to a 4" downpipe
Old Nov 29, 2006 | 05:59 AM
Schister66's Avatar
Man U FTW
i'm pretty sure someone on HT can get you a 3" dp that will clear ac....i know that ProjectDC2 makes dp's for other manifolds like Drag, he might make one for FMax....
Old Nov 29, 2006 | 06:39 PM
downsouth0's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty sure someone on HT can get you a 3" dp that will clear ac....i know that ProjectDC2 makes dp's for other manifolds like Drag, he might make one for FMax....</TD></TR></TABLE>
I just need to find out who makes them
Powelly
Mar 26, 2010 09:29 AM
B18 CYA
Apr 27, 2004 12:38 PM
skhonda
Jan 22, 2003 06:10 PM
98civicEX
Jun 25, 2002 05:01 AM
CalvitoSol
Jun 8, 2002 12:36 AM
