ne Passenger side corner light works only when turn signal is on...
anyone got any idea what this could be?
The passenger corner light stays off until I turn on my turn signal and then it blinks like normal ... I replaced the bulb, any other ideas?
TIA
TIA
same problem here... i'm sure it's an easy fix.. i just work too much. without using my meter.. i'm guessing that it's just not getting any current from the parking light relay which could mean it's a bad relay or the wiring is fried. if u understand relay's u can easily jump the wiring from the working light to the non working light. there should be three wires.. one ground, one parking light, one flasher relay wire. just use the park light wire and u should be good. i'll be doing that as soon as i get time. which is in a month or so. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">And it could also be the socket plug.</TD></TR></TABLE>
upstate
Jul 21, 2004 12:46 PM
