Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
NEX Coilovers - $599 and up
Old Nov 28, 2006 | 07:03 PM
prostreetonline's Avatar
Default NEX Coilovers - $599 and up
<FONT COLOR="blue"><FONT SIZE="5">PM for a special installed price! We are in Hayward, CA </FONT></FONT>
These NEX GT coilovers are the performance offering from NEX for your vehicle when you want to perform like many of the other high priced suspension company cars out there, but without the high priced company name and price tag. The NEX GT Coilovers are height adjustible as well as 4 way shock adjustable, and allow a broad range of height adjustibility while providing more than enough dampening for any height adjustment.
Order <FONT COLOR="blue">NEX GT Coilovers</FONT> here!
These NEX SS coilovers are the performance offering from NEX for your vehicle when you want to perform like many of the other high priced suspension company cars out there, but without the high priced company name and price tag. The NEX SS Coilovers are height adjustible, and allow a broad range of height adjustibility while providing more than enough dampening for any height adjustment.
Order <FONT COLOR="blue">NEX SS Coilovers</FONT> here!
Features Include:
Steel Upper Mount - Every NEX System comes equipped with steel upper mounts so that you don't have to disassemble the original shock units to complete the suspension kit. The steel upper mounts help to equally distribute the weight and force of the shock tower. The high-density rubber pads helps to reduce road noise and keep the car properly aligned.
High Molecule Force Coil Springs - The coil springs in the NEX suspension is made from high molecule forced steel. After being tested by millions of times on our dyno, we found this spring construction to resist wear and tear, and sustain its efficiency and consistent spring rate. The handling and performance can match by the skill of each driver due to the high spring rate used in the NEX suspension
Adjustable Ride Height - NEX feature a wide range for height adjustments without changing the spring compression and sacrificing the shock stroke. Traditional Hi-Low Kits (coil-over) require the movement of the spring perch to determine the ride height, causing a reduction in suspension travel and induce coil spring binding. The bottom shock fork/connector is threaded to allow height adjustments to each driver's need without having to shorten the suspension travel by maintaining the original spring perch location. With this function, each driver can lower the center of gravity to achieve better handling and still maintain a consistent ride quality. Because of the wide range of height adjustments, the driver can set his car to his preference of appearance without altering the factory tuned spring/shock suspension system.
Inner Bump Stop - Although the inner bump stop can't be seen from the outside of the shock, NEX includes on with every application to prevent damages caused by the rapid and lethal compression impacts from the road surface to the inner structure of the shock.
Mono-tube shock absorber - Whether being touring, rally or even formula 1 racing, most engineers of these professional race teams, would prefer using a mono tube shock absorber as a foundation for their suspension system. The is due to the fact that the mono tube shock absorber can cool off faster from the direct contact with the outside air. This in turn will aid in the prevention of shock cavitations (boiling of the shock oil at high temperature) which allows the suspension to perform better under aggressive driving.
Modified by prostreetonline at 9:04 PM 5/7/2007
Old Nov 29, 2006 | 01:06 AM
lil ef9's Avatar
Default Re: NEX Coilovers - $599 and up (prostreetonline)
pm'd
Old Dec 1, 2006 | 11:32 AM
Default Re: NEX Coilovers - $599 and up (lil ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lil ef9 &raquo;</TD></TR><TR><TD CLASS="quote">pm'd </TD></TR></TABLE>
Old Dec 9, 2006 | 04:15 PM
Plenty in stock, thanks for your orders!
Old Dec 9, 2006 | 06:09 PM
b16boo's Avatar
thanks for the NEX GT!
Old Dec 10, 2006 | 03:29 PM
b20_ed's Avatar
Default Re: NEX Coilovers - $599 and up (b16boo)
ooops, pm sent!
Old Dec 14, 2006 | 09:53 PM
beak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16boo &raquo;</TD></TR><TR><TD CLASS="quote"> thanks for the NEX GT!</TD></TR></TABLE>
had these on my car too
Old Dec 20, 2006 | 03:34 PM
Thank you for your orders!
RickR
Jun 8, 2010 04:51 PM
prostreetonline
44
Aug 27, 2009 11:56 AM
prostreetonline
Jul 16, 2007 10:24 AM
prostreetonline
Mar 11, 2006 08:11 PM
