Want to Buy Want to Trade/Want to Buy
WTB : RHD EG6 Driver Side Power Window Switch (USDM WONT WORK) so cal
Old Nov 28, 2006 | 06:57 PM
KamiKazeEG's Avatar
Default WTB : RHD EG6 Driver Side Power Window Switch (USDM WONT WORK) so cal
hey there peeps, well i just can not get my power windows to work on my eg6. switch gets power, motors work .. .. all my window fuses are fine and in the right place, i followed the power window harness and it goes throu the driver side kick panel and is pluged into the fuse box under dash. i cannot locate any rhd power window switches for eg6. i tried switches from a ej coupe. but i got nothing. but when i used my window switch in a usdm ej coupe, i blew 2 power window fuses, so im guessing either i have a bad window switch or maybe a wire is cut thru my harness . . i hate wiring . . . anyhow yea if i could find a switch that would be kool . . any 1 know how 2 see if my switch is good?
Old Nov 30, 2006 | 11:48 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: WTB : RHD EG6 Driver Side Power Window Switch (USDM WONT WORK) so cal (KamiKazeEG)
i should have this part but have you considered wiring to a 12v power source to bypass the harness?
Old Nov 30, 2006 | 06:30 PM
KamiKazeEG's Avatar
no i havnt . .. wiring is absolutely not my thing . . ill look into that . . . thanx for the info . . anything else i should consider?
Old Nov 30, 2006 | 08:16 PM
kwest10's Avatar
well well well...i have some but dunno if I can get rid of them.
I'm assuming you're using RHD doors? I bought RHD doors since i wanted PW and mirrors and needed new glass etc it was cheaper buying new doors and I could just switch the panels.
NE way. A couple of things that are different with the RHD doors are that mine don't have PDL for one and the RHD switch panel also has an auto UP feature for the driver side. SO it could be that your harness is missing a wire or 2 and it's getting messed up or if you're using the USDM relay that may be the problem.
I too can't STAND wiring but those were my thoughts and issues I thought I might have as well.
So you have USDM switches but what is the dash and in door hardware? USDM or JDM? and what is the PW relay...US OR JDM?
Old Nov 30, 2006 | 10:37 PM
hatchi's Avatar
I didnt see you mention the relay that goes into the fuse box. do you have that in there??
Old Dec 1, 2006 | 12:07 AM
Vincent.'s Avatar
Default Re: WTB : RHD EG6 Driver Side Power Window Switch (hatchi)
pm'd.
Old Dec 1, 2006 | 12:57 PM
KamiKazeEG's Avatar
im sorry i didnt mention that it is a real deal jdm car, so i didnt convert anything . . when i got the car the windows were down and never worked . . so i do have both jdm window switches and complete harness was there . .
anyhow i thought the PW relays were built into the switch on the eg? ur saying theres a relay in the fuse box too? when i checked theres four 20amp (yellow) fuses . . theyre all ok, theres also a relay on the fuse box too?
Old Dec 1, 2006 | 12:59 PM
KamiKazeEG's Avatar
pm'ed G
rwp011
Dec 16, 2011 05:13 PM
VtecCivic93
May 5, 2008 03:47 PM
blu_g2
Nov 10, 2006 05:04 PM
Ej1_coupe
May 29, 2006 06:39 PM
