Rear brakes dragging
Old Nov 28, 2006 | 03:33 PM
92ehatch's Avatar
Default Rear brakes dragging
Ok ive had issues with my brakes before so its not too surprising that im having more trouble.
about 10k miles ago i put on new shoes because mine were shot.
well i started noticing alot of brake dust building up on the rear wheels and now my rear brakes are screeching, i think the shoes are already shot. Anyways, i gutted the rear portion of my hatch for another project and now i can hear the brakes dragging.
i did not put the shoes on, a friend did it for me at work (toyota dealer).
i already adjusted the ebrake but thats not making a difference. What could cause the rear brakes to drag so bad that it could wear them out in 10k miles?
what should i be looking into replacing to fix it?
if its too much ill just do a disc brake swap, but id rather save my money for other things.
i searched but only found 1 thread on dragging brakes and didnt really give me much info.
i read something about the adjuster inside the drum, i understand how to use it, but my friend said he adjusted it when he installed the drums. possibly done wrong?
thanks for any info
Old Nov 28, 2006 | 03:44 PM
h_s's Avatar
h_s
its near impossible for your adjusting wheel to over adjust, check your brake drum, could be warped or out of round
Old Nov 28, 2006 | 03:57 PM
92ehatch's Avatar
Default Re: (h_s)
they were turned when the shoes where installed
sorry forgot to mention
Old Nov 28, 2006 | 04:26 PM
97civicdx's Avatar
Default Re: Rear brakes dragging (92ehatch)
Parking brake cables gone bad?
Old Nov 28, 2006 | 04:52 PM
92ehatch's Avatar
Default Re: Rear brakes dragging (97civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx &raquo;</TD></TR><TR><TD CLASS="quote">Parking brake cables gone bad?</TD></TR></TABLE>
never heard of such a thing but that doesnt mean it isnt possible.
but i believe the cables are fine. they arent damaged or anything like that.
what about the spring inside? i havent had a chance to open the drum and actually take a look.
or even the hydrolic part of the brakes? i know that they are hydrolic too, so there must be some sort of cylinder or similar device in there correct?
i dont know anything about drum brakes, and hardly anything about brake systems, so thats why i dont know wtf im doing lol
Old Nov 29, 2006 | 01:12 AM
97civicdx's Avatar
Well, water can get in and rust the cable. Ive seen it many times. Its very common in VW's and Nissans.
Old Nov 29, 2006 | 12:12 PM
teal_dx's Avatar
yep, mine would get stuck sometimes. so I had to crawl under on the pass side and jiggle the parking break cable. Then it would release and be back to normal. I fixed it by not using my parking brake anymore
Old Nov 29, 2006 | 03:12 PM
92ehatch's Avatar
Default Re: Rear brakes dragging (teal_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx &raquo;</TD></TR><TR><TD CLASS="quote">yep, mine would get stuck sometimes. so I had to crawl under on the pass side and jiggle the parking break cable. Then it would release and be back to normal. I fixed it by not using my parking brake anymore </TD></TR></TABLE>
ill have to check that this weekend for sure. if i cant find it i guess its disc brakes for me
up for any more possibilities
Old Nov 29, 2006 | 03:16 PM
ilovemysedan's Avatar
i had the same problem on my four door.. it ended up being a warped drum but they ended up getting replaced with a wilwood kit
EL Vap133
Honda CR-V & Element
12
Aug 11, 2014 05:34 PM
killacam661
Feb 5, 2009 10:30 AM
Bond
Oct 2, 2005 02:05 PM
hybridbook
Jun 12, 2003 10:18 AM
