? on B16A block
Old Nov 28, 2006 | 03:12 PM
Evil_1's Avatar
Default ? on B16A block
I got a B16A block that I would like to replace my current B16A2 with. The B16A looks a little different than the A2. What's the 2 oil line coming out where the oil filter bolts to go? The A2 block does not have those two prongs. What do I need to do to get it to work on my B16A2 head? One of my cylinder wall has deep scuffs on the walls and that's why I need to replace the block. Here's a pic of what I'm talking about. Any help is appreciated. Thanks
Old Nov 28, 2006 | 03:19 PM
BlueIntegraBoy's Avatar
Default Re: ? on B16A block (Evil_1)
oil cooler
Kruzen510's Avatar
jdm motors came with an oil cooler. those two lines coming off of it are coolant lines. on mine, they loop through that coolant bar that goes from your water pump to your thermo housing. your usdm coolant bar will not have any lines coming off of it for your cooler though since usdm motors didn't come with that. at least thats how my b18c was.
Old Nov 28, 2006 | 03:27 PM
Default Re: ? on B16A block (Kruzen510)
obd1 b18c1 had oil cooler
Old Nov 28, 2006 | 03:31 PM
Archidictus's Avatar
Unceasing Measure
Default Re: ? on B16A block (BlueIntegraBoy)
Just loop the lines and you'll be fine.
Old Nov 28, 2006 | 04:18 PM
Evil_1's Avatar
Default Re: ? on B16A block (Archidictus)
Thanks, that helps.
4gencivicef9
Aug 15, 2009 09:09 AM
4gencivicef9
Aug 15, 2009 08:14 AM
tfeagley
Feb 9, 2009 07:16 AM
Frozen E
16
Apr 25, 2006 05:06 PM
Chris_
Apr 6, 2004 11:10 AM
