anyone wire vtec to activate using a shift light?
Old Nov 28, 2006 | 07:26 AM
97grnrs's Avatar
Default anyone wire vtec to activate using a shift light?
im prob putting a SOHC vtec in my crx and i dont wanna convert or get an msd activation switch so i was thinkin set my shift light to come on wherever vtec is supposed to activate on the d16z6 motor and wire the + wire of the solenoid to the shift light signal wire.. would that work?i dont see why not
Old Nov 28, 2006 | 09:34 AM
02 accord's Avatar
Default Re: anyone wire vtec to activate using a shift light? (97grnrs)
Should work. Just make sure that you don't fry the shift light driver by hooking up a solenoid that pulls more power than the bulb.
Old Nov 28, 2006 | 01:18 PM
playskool's Avatar
Default Re: anyone wire vtec to activate using a shift light? (02 accord)
what ecu will you be running? the rpm activated pill will activate vtec, but what are you going to do about the fuel map?
Old Nov 28, 2006 | 03:54 PM
97grnrs's Avatar
Default Re: anyone wire vtec to activate using a shift light? (usdm sleeper)
car is turboed so it should be feeding enough fuel already . it runs rich as it is
Old Nov 28, 2006 | 06:44 PM
HondaPartsHero's Avatar
Technical Hero
this is for a switch, but just run the 12v switched (terminal 86 on the bosch relay)from the shift light instead at whatever RPM you set it at
Modified by HondaPartsHero at 5:29 AM 11/29/2006
Old Nov 29, 2006 | 01:38 AM
91SiZ6's Avatar
Just run the car correctly. You won't have the timing or fuel maps for VTEC.
Old Nov 29, 2006 | 05:08 AM
SOHFAST94's Avatar
Default Re: (91SiZ6)
Agreed.
civicdust
Nov 8, 2004 02:51 AM
ham
Jul 8, 2004 05:58 AM
s2kkk
May 10, 2004 09:33 AM
down_hill_dog
Jan 25, 2004 07:11 PM
Hondasaurs
Apr 21, 2003 01:57 PM
