tensioner problem need help asap.D16Z6
Old Nov 28, 2006 | 05:34 AM
bluebeast's Avatar
Default tensioner problem need help asap.D16Z6
replaceing cam belt and stripped threads for the bolt that goes through middle of tensioner,antbody know anythig i can do to repair this without removing motor.any suggestions would be greatly appreciated.D16z6 engine.
Old Nov 28, 2006 | 06:18 AM
MrRealityman's Avatar
Default Re: tensioner problem need help asap.D16Z6 (bluebeast)
new bolt, reem, and thred in that order.
Old Nov 28, 2006 | 10:46 AM
bluebeast's Avatar
Default Re: tensioner problem need help asap.D16Z6 (MrRealityman)
bolt is fine its the thred in the side of the block thats stripped,any ideas?
Old Nov 28, 2006 | 11:41 AM
starlord's Avatar
buy a tap set...
you can rethread the hole or use a helicoil to keep stock bolt
http://contractorstools.com/helicoil1.html
D_CRX_Si
Mar 10, 2006 10:42 AM
BROKE.eg
17
Nov 25, 2005 08:19 PM
seeeya04
Nov 24, 2005 03:25 PM
XDEep
Sep 18, 2004 09:37 PM
Renegade
15
Sep 22, 2003 06:28 AM
