CTR in a GSR??
Old Nov 27, 2006 | 10:26 PM
GReddyjon's Avatar
Default CTR in a GSR??
I just bought CTR pistions for my 99 GS-R motor
I was curious to know if there were any compression problems and wanted to see if any one else had tried it before
Old Nov 27, 2006 | 10:40 PM
doood's Avatar
been there done that
Default Re: CTR in a GSR?? (GReddyjon)
search in the all motor forum. you'll find more than enough info.
Old Nov 27, 2006 | 10:54 PM
I Shot 50 Cent's Avatar
Just curious...why did you buy them? Do you have any idea if the CR will be ideal for your build?
Old Nov 27, 2006 | 11:40 PM
fmrprojects's Avatar
Default Re: (I Shot 50 Cent)
he compression is gonna be high and you gonna need to pump race gas. shoulda just went with the itr or b16 pistons
Old Nov 28, 2006 | 02:44 AM
sheekdude's Avatar
There would be no compression problems. Ctr is about 11.6-1 cr so you would be close to 12-1 in a gsr motor... hence you should be using at least 91-93 octane gas.
The problem is that ctr pistons have a higher dome so the pistons will be hitting the valves. You would have to get the head checked for clearance.
Old Nov 28, 2006 | 03:35 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: CTR in a GSR?? (sheekdude)
Yeah, it'll be like 12:1. But why the hell did you buy pistons before knowing what you want?
Old Nov 28, 2006 | 04:38 AM
teamvirus's Avatar
My car breaks a lot!
Default Re: CTR in a GSR?? (Stinkycheezmonky)
my friend has them in his ls/vtec....made great power gains, just used 91+ octane
Old Nov 28, 2006 | 05:33 AM
cranny's Avatar
24.224.233.247
Default Re: CTR in a GSR?? (teamvirus)
your gonna need to take them to a machine shop and have them milled down a bit , not even a milimeter. factory , the compression height of CTR pistons is 30.73mm. they need to be milled to have a compression height of 30.10mm. this will give you piston to deck of .032". GSR stock is .034". CTR stock is .026". youl have approx 12.1:1 CR.
iHeartIntegraDA
Mar 17, 2005 04:01 PM
jeremy.
199
Dec 23, 2004 03:45 PM
ek9dc2
Oct 13, 2003 08:12 PM
akhom
Oct 13, 2002 10:21 PM
94gsr4d
Feb 4, 2002 02:53 PM
