How hard is installing a camshaft?
Old Nov 27, 2006 | 07:26 PM
Nongan's Avatar
Default How hard is installing a camshaft?
How hard is installing a new camshaft? Is it within the bounds of someone who's never worked on an engine before? Or should I look to someone else for some help? Also, what all would I need to do it? Sorry for the newb question.
Old Nov 27, 2006 | 08:23 PM
loudassVTEC's Avatar
Default Re: How hard is installing a camshaft? (Nongan)
The actual installation is pretty straight forward. The hard part is getting the engine timed right. If you've never done it before, you can easily eff it up. The hardest part I found for me was setting the valve clearances. You'll also need to get it tuned so you can take advantage of the higher lift and duration (airflow). You also need to think of getting better springs/retainers if you are running anything bigger than a CTR camshaft, and they are a must if you plan on revving higher than the factory rev-limiter (a lot of cams make power higher up in the powerband). What engine are you running? And what cams are you planning on swap in??
Old Nov 27, 2006 | 08:34 PM
Nongan's Avatar
Default Re: How hard is installing a camshaft? (loudassVTEC)
right now i'm running a d16a6, and i'm ordering a delta 272 camshaft.
Old Nov 27, 2006 | 09:05 PM
91SiZ6's Avatar
You'll want aftermarket springs and retainers for that cam. Ask Delta who they recommend.
Old Nov 27, 2006 | 09:23 PM
Nongan's Avatar
Default Re: (91SiZ6)
How much would springs and retainers run for something decent? Maybe so I can take the motor up to 7.5k where the cam is still making power?
Old Nov 28, 2006 | 08:47 AM
Nongan's Avatar
Default Re: (Nongan)
bump
Old Nov 28, 2006 | 11:00 PM
Nongan's Avatar
ttt
Old Nov 29, 2006 | 04:54 PM
PrettyLude's Avatar
the only way to see if the cam is still making power would be to strap it to the dyno and see it go to 7.5k
springs retainers and whatever, just depends on what you like and what your budget is like
Old Nov 30, 2006 | 04:59 PM
Default Re: (PrettyLude)
Portflow makes some good springs and retainers at a decent price.
I agree with the post above me...you gotta get it on the dyno to see where it makes power, and where it drops off at.
Old Nov 30, 2006 | 07:18 PM
GSaura's Avatar
Here's a how-to for ya. http://www.c-speedracing.com/h...m.php
oops. Just noticed you had a d-series. Ah well, this'll give you the basic idea of how difficult it will be I suppose
all-mtr-teg
Sep 10, 2009 06:50 PM
boosted94cx
Apr 20, 2006 09:30 PM
NonovUrbizniz
19
May 25, 2005 10:22 AM
CRXSleeper
Sep 9, 2002 10:47 PM
sa21199
Feb 25, 2002 05:46 AM
