94 Civic wont start need help
about 3 weeks ago my battery drained while my car was sitting for 2 days when i started to drive my new car to school. we tested the battery and it still holds charge. my trunk light occasionally stayed on so we disconnected that but something was still draining the battery. we disconnected the starter and the battery still drained, we recharged the battery and it started up right after then we disconnected the alternator and the battery kept a charge so we replaced the alternator and reconnected everything and it wont start even with a fully charged battery i assume its either fuel or spark but the car started up once we recharged the battery and reconnected the starter and that was less than a week ago thx for ny help
well it sounds like you have the problem narrowed down a little so check those 2 things and let us know what you find! If you have a fuel problem it could be the main relay or the fuel pump. If you have no spark pull the cap and rotor off and check your coil and igniter.
