changing throttle body.. iacv question.
i want to put a gsr throttle body on my 97 auto ex. i think the iacv is a three wire on my car and the gsr doesn't have an iacv on the throttle body. can i put a 5speed throttle body on my d16y8 auto? and if so what problems will i run into.
If you're sticking with an auto ECU, your only option is to go with a throttle body with the 3-wire IACV integrated into it. There are no work-arounds for this.
You could swap intake manifolds... If you IE get an Y8 manifold, the IACV will be on the back on the manifold, and you'll have a much less restrictive intake.
If you're going OBD1, just get a Z6 manifold instead.
It's even better than the Y8 anyway.
DarkDaysX6
Jul 9, 2013 05:53 PM
javifunksEK
10
Feb 28, 2011 08:10 PM
