d15z1 with a d16z6 with boost
so i need another motor for my car because mine overheated and the guage never moved and this motor is kinda fuxed..
my spare motor is a d15z1.. i did the compression calculator it comes up to 8.04:1 with the d16y8 head and oem 3 layer hg
is that too low compression for this setup?? i know it has the d16 rod length.. but are the rods as strong as the d16's?
just need something for now until i build my other shortblock thats torn apart... thanks.. also how much psi should this setup hold?? right now im using a z6 with a y8 head shaved 20 with an a6 .048 headgasket at 12 psi tuned
thanks
Modified by siregcivic at 12:25 AM 11/27/2006
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20EP3 »</TD></TR><TR><TD CLASS="quote">No that isn't to low it should be fine</TD></TR></TABLE>
sweet thanks man.... it will be put together tomarrow then...
anyone have any info on the rods tho??? i know they are the same length 137mm as the d16 blocks.. but are they the same size.. like the strength are they as strong??
Eg2707
12
Dec 22, 2006 03:21 PM
