How to remove oil stain from concrete?
Old Nov 26, 2006 | 05:56 PM
jrockets's Avatar
Default How to remove oil stain from concrete?
Yea I am wondering if any of you have any secrets or products that will remove oil stains from concrete?
Old Nov 26, 2006 | 05:57 PM
jdmztrane's Avatar
Default Re: How to remove oil stain from concrete? (jrockets)
Try some of the generic degreasers in their concentrated from along with a pressure washer. Should come right out, unless its been on the concrete for a long time.
Old Nov 26, 2006 | 05:58 PM
Reza^'s Avatar
go to homedepot and ask what you can use..
Old Nov 26, 2006 | 06:03 PM
jrockets's Avatar
Default Re: How to remove oil stain from concrete? (.:Reza:.)
does anyone know if pour-n-restore.com work...
Inline6 Silvia's Avatar
brake cleaner
Old Nov 26, 2006 | 06:05 PM
.Beaver's Avatar
Bloody Beaver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:Reza:. &raquo;</TD></TR><TR><TD CLASS="quote">go to homedepot and ask what you can use..
Old Nov 26, 2006 | 06:10 PM
bart2546's Avatar
Default Re: How to remove oil stain from concrete? (Teal-EJ1)
If it's fresh, some stuff called "purple power" letting it soak for a few, then a high powered pressure washer FTW. Or put down some generic kitty litter and then using the above. Other than that, brake cleaner works well.
Old Nov 26, 2006 | 06:17 PM
kyle h.'s Avatar
again too much effort...
brake cleaner and rags always worked for me.
Old Nov 26, 2006 | 06:24 PM
life sux die's Avatar
RIP 1032
Default Re: How to remove oil stain from concrete? (Yellowone)
tide with bleach worked for me!
Old Nov 26, 2006 | 06:39 PM
jdmazm's Avatar
Default Re: How to remove oil stain from concrete? (EK Josh)
degrease then dump on some kitty litter, then degrease one more time.
Old Nov 26, 2006 | 09:14 PM
Reza^'s Avatar
this thread is done.
go to home depot.
Old Nov 26, 2006 | 09:41 PM
plan B.'s Avatar
try starting fluid. you can get it at kragen or something. i used it the other week and it worked great. i guess it has like ether or something in it and its only like 2 bucks a can.
Old Nov 26, 2006 | 09:57 PM
ATS*VEEE's Avatar
Default Re: (plan B.)
if its fresh OIL stain...try COKE...yes COKE...coca-cola..hahah...it works somewhat...and wash if off with water
Old Nov 26, 2006 | 10:11 PM
BoostedCivicChic's Avatar
castrol degreaser...in concetrate 1 gallon purple bottle in the automotive section at most places like wal-mart mix with water (real ****)
Old Nov 26, 2006 | 10:50 PM
prettycivic's Avatar
You can't.
Old Nov 26, 2006 | 10:52 PM
plan B.'s Avatar
Default Re: How to remove oil stain from concrete? (prettycivic)
yes, you can. have you even ever tried starting fluid?
Old Nov 26, 2006 | 10:57 PM
DOMKID's Avatar
Default Re: How to remove oil stain from concrete? (plan B.)
pressure washer and some chemicals should fix the problem, but its very hard to take it completely off.
Old Nov 27, 2006 | 10:14 AM
Azn Kenny's Avatar
Pave new concrete over it...
Old Nov 27, 2006 | 11:44 AM
gsrious's Avatar
go and buy some balck paint and paint the whole drive way/garage floor black. then you wont have to worry about the stain anymore.
^j/k
you should always wipe off any excess oil first. then do what others have said. repeat those muiltiple time for a lasting effect.
Old Nov 27, 2006 | 10:59 PM
Shack,96's Avatar
tide with bleach does the trick for me also,use broom then pressure washer.
alexsracing
Jan 23, 2008 06:07 PM
JDMCRX
Welding / Fabrication
19
Jan 3, 2008 09:28 AM
robble36
Oct 8, 2007 07:54 PM
Rhetoric
Aug 6, 2003 12:59 AM
Soon_2b_evil
Jul 18, 2003 05:36 PM
