What is seafoam?
Old Nov 26, 2006 | 05:54 PM
hondachris1994's Avatar
Default What is seafoam?
what does it do and does it work, and how much does it cost?
Old Nov 26, 2006 | 05:58 PM
EG2Driver's Avatar
Default Re: What is seafoam? (hondachris1994)
use the seach button
cleans the carbon from ur engine
Old Nov 26, 2006 | 05:59 PM
bart2546's Avatar
Seafoam comes in an aluminum, usually white can, it ranges from about 4 to 6 dollars a can depending on where you live, usually 5.50, give or take a few cents. It's designed to clean out engines by using it as an additive to usually one of 3 things: Your PCV/Brake booster line, Crankcase oil, or gas tank. Some claim that it works wonders, some say no, and some are scared to use it. I personally have used it in my Subaru and can vouch it does help, although all I ever did was use it through the PCV valve. When used through that line, it evenly distributes to each cylinder and will "burn off" carbon deposits on the valves and piston heads. Putting it in the crankcase will thin the oil and get rid of sludge and grime which is why you want to change oil within a few miles of adding it to oil. Finally, adding it to the gas will clean your lines/filter/injectors to provide a clean flow for fuel. For more information please visit the search button and type in H-T keyword "Seafoam".
Old Nov 26, 2006 | 06:01 PM
stuie08's Avatar
it takes away all the carbon build up, and cleans your engine pretty much. yes, for me and my brother it worked amazing, better gas mileage, and our cars drive a lot stronger. It costed us 6.99 a can at NAPA. we used 1 can per car; 1/3 can in brake booster line, 1/3 in crankcase, and 1/3 in gas tank.
ALSO TRY SEARCHING!! press search, then type in what, then press acheived, then what category. and you'll get a lot of info.
Old Nov 26, 2006 | 06:02 PM
schardbody's Avatar
its MAGIC, hope everyone likes doing valve stem seals.
so its just like a induction service?
Old Nov 26, 2006 | 06:05 PM
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">its MAGIC, hope everyone likes doing valve stem seals.</TD></TR></TABLE>is it hard on valve stem seals?
Old Nov 26, 2006 | 06:07 PM
bart2546's Avatar
Default Re: (hondachris1994)
The way it's hard on them is one of two ways, 1)Putting too much in at once and over-pressurizing the valves 2)If carbon buildup has already gotton the best of your engine, and now the seals are basically the carbon itself, when the seafoam eats the carbon away, your valves will be seal-less
Old Nov 26, 2006 | 06:40 PM
tha_badguy's Avatar
i recently used seafoam & now my o2 is shot
besides that my car idles alot better & much quieter
Old Nov 26, 2006 | 06:42 PM
schardbody's Avatar
exactly what i meant. good preventative mantainence, not so good for a high mileage motor.
Old Nov 26, 2006 | 09:46 PM
hatch96y7's Avatar
i bought a can about a month ago and im scared to use it because i have a d16y7 with about 130000 miles on it should i use it or not or what will be the safest way threw the intake manifold or threw the gas tank or crank case
and if i put it in the gas tank do i have to change the oil
Old Nov 26, 2006 | 10:04 PM
Minglor's Avatar
Default Re: (hatch96y7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">i bought a can about a month ago and im scared to use it because i have a d16y7 with about 130000 miles on it should i use it or not or what will be the safest way threw the intake manifold or threw the gas tank or crank case
and if i put it in the gas tank do i have to change the oil</TD></TR></TABLE>
You should change oil after seafoaming anyways
Add it VERY slowly.
I put it in a plastic cup and very slowly added about 2/3s a bottle down the brake booster line and the other 1/3 into the crank case.
Drove about 50 miles and changed my oil.
Idle is nicer but that was about it.
Old Nov 26, 2006 | 11:06 PM
travisallenn's Avatar
seafoam is t3h pwn
Old Nov 27, 2006 | 01:13 PM
BuiltforSin's Avatar
i wanna use it, but im scared. i have a Y8 with around 105k on it. I dont wanna any leaks or problems. cant afford it.
Old Nov 27, 2006 | 01:54 PM
hatch96y7's Avatar
Default Re: (mugenej8power)
do u think i should use it if i have 130000 miles on my motor
Old Nov 27, 2006 | 02:16 PM
thesmogman's Avatar
I used it. 215,000 on my old D16A6. I have used it on numerous cars with no ill effects for purposes of passing emissions tests.
I don't use it in the oil, just the IM and gas tank. I use it through a small vacuum line instead of the booster.
It says right on it ok for O2 sensors and cats.
The higher mileage motors are the ones with the carbon build-up, that is what it is suppose to be used for.
Go For It!
Old Nov 27, 2006 | 02:45 PM
big-cat's Avatar
i was going to search but now that are we already on the subject. when would u guys reccomend using it and seeing affects??(76,000mi on my car) and if i only put it in my gas tank do u think i should put only like 1/2 tops??? thanks if i dont get flamed.
Old Nov 27, 2006 | 03:35 PM
thesmogman's Avatar
Default Re: (big-cat)
I would go with 1/3 every other oil change. With 76K you shouldn't have the build-up we have with 150,160K, or 200K.
Old Nov 27, 2006 | 04:13 PM
EFvtec Yo!'s Avatar
Default Re: (thesmogman)
Seafoam have used it in numerous cars and usually always see some kind of positive effect. Used it a month ago in a friends EF and I wish you could have heard the before and after idle on this car. I've never been a fan on putting it in the oil, I usually just put over half in the gas tank and the rest through the Intake Mani via the brake booster line.
Old Nov 27, 2006 | 04:51 PM
Default Re: (tha_badguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">i recently used seafoam & now my o2 is shot
</TD></TR></TABLE>good thing my O2 sensor is disabled
Old Nov 27, 2006 | 04:53 PM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">I used it. 215,000 on my old D16A6.
Go For It!</TD></TR></TABLE>
I wanna use it, but i dont wanna have to rebuild an engine because it ate thru the carbon seals....my car has 243 xxx miles on it, the maintenance has been kept up to date really well...im just so worried.
OblivionLord
Aug 30, 2008 08:40 PM
musifuger
Mar 11, 2007 04:30 PM
central_driver
Jul 9, 2006 03:45 PM
drewbie
12
Feb 6, 2005 05:18 PM
jonnybravo
Apr 29, 2003 09:27 AM
