"Aftermarket Chips"
Old Nov 26, 2006 | 05:29 PM
Elbowpunk's Avatar
Default "Aftermarket Chips"
ok.. so where can i get a program to make my own or what do i need to do my own...
for a 90 gs teg... im doing some research now, but i still like help
thankts
Old Nov 26, 2006 | 06:19 PM
Code Blue's Avatar
Default Re: "Aftermarket Chips" (Elbowpunk)
chip a p28, and you can run uberdata or another one of those chips. you will need to buy the burner as well
Old Nov 26, 2006 | 08:26 PM
doood's Avatar
been there done that
Default Re: "Aftermarket Chips" (Code Blue)
http://www.pgmfi.org
Old Nov 26, 2006 | 08:30 PM
Confuzious's Avatar
Ive heard a lot of both good and bad about reflashing the ECU's.
Old Nov 26, 2006 | 08:34 PM
doood's Avatar
Default Re: (Speedsixed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedsixed &raquo;</TD></TR><TR><TD CLASS="quote">Ive heard a lot of both good and bad about reflashing the ECU's.</TD></TR></TABLE>
honda ecu's arent reflashed. unless it's a k series ecu. and what specifically have you heard?
Old Nov 27, 2006 | 11:40 AM
Elbowpunk's Avatar
so i checked that site out... i looked under the dlownloads, a program called Turboexe or something close to that if i dl it what can i run chip wise to mod my ECU ?? any sites for the chips ???
Old Nov 27, 2006 | 12:11 PM
Ruben19's Avatar
do you have any engine mod.
if so, get a kenji p06 ecu and he will make you a custom chip.
you will have to go with a obd0 to obd1 jumper hadness .
http://www.kenji211.com
Old Nov 27, 2006 | 12:44 PM
Fat Chick Magnet's Avatar
what rpm does vtec engage on a p28 ecu and what rpm is the rev limiter at?
Old Nov 27, 2006 | 02:56 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Elbowpunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk &raquo;</TD></TR><TR><TD CLASS="quote">so i checked that site out... i looked under the dlownloads, a program called Turboexe or something close to that if i dl it what can i run chip wise to mod my ECU ?? any sites for the chips ???</TD></TR></TABLE>
Read through the site more thoroughly. There is a large amount of information there, and it will undoubtedly answer the majority of your questions.
Old Nov 27, 2006 | 08:10 PM
Elbowpunk's Avatar
ok... cool as far as mods... all stock execpt, I/H/E
Old Nov 28, 2006 | 05:21 AM
Code Blue's Avatar
contact h-t member PHiZ for the win
laboyon
Aug 27, 2008 09:10 AM
EGLUVN
Mar 19, 2008 02:00 PM
BoredRec
Sep 27, 2004 09:31 PM
Cyphear
Aug 5, 2004 06:11 AM
systemoverload
Jun 12, 2004 09:31 AM
