92 cx with d16z6 using 95 ex harness....throwing code1
Old Nov 26, 2006 | 01:48 PM
peiku's Avatar
Default 92 cx with d16z6 using 95 ex harness....throwing code1
this has probably been covered before but i couldnt find any info. i tried the search function but it wouldnt let me search for "cx". i have a 92 civic cx with a d16z6 swap. i am using a 95 civic ex engine harness. the ecu is throwing a code 1. i bought a new bosch o2 sensor but no luck. i was under the assumption that it would run fine with the ex harness. are there some wires that i have to repin or do i have to add wires straight to the ecu? thanks for any help.
Old Nov 26, 2006 | 02:56 PM
hatchi's Avatar
Default Re: 92 cx with d16z6 using 95 ex harness....throwing code1 (peiku)
what ecu are you running. you will need to run the wires for the 4 wire o2 because the cx only had a 1 wire
Old Nov 27, 2006 | 05:07 AM
peiku's Avatar
Default Re: 92 cx with d16z6 using 95 ex harness....throwing code1 (hatchi)
ooops...i forgot to mention that i am running the p28.
chevmaro
11
Jul 11, 2011 09:23 PM
T-RO
Aug 6, 2008 03:10 PM
vtec25
Aug 18, 2005 04:39 PM
SLowCrx
Dec 19, 2003 04:10 AM
itr0032
Nov 20, 2001 04:31 PM
