B16a2 tranny
this is a model spacific forum...the major tech part is another 10+ down hence why i didnt post in there.......for your pleasing i will add that i need a b16a2 tranny because the ratios most resemble the type R tranny and i would like to put LSD in it, i have a LS tranny it it is killing my all motor setup because it is most designed for turbo apps hence the long gears.......Is that technical enough for you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96typeR »</TD></TR><TR><TD CLASS="quote">this is a model spacific forum...the major tech part is another 10+ down hence why i didnt post in there.......for your pleasing i will add that i need a b16a2 tranny because the ratios most resemble the type R tranny and i would like to put LSD in it, i have a LS tranny it it is killing my all motor setup because it is most designed for turbo apps hence the long gears.......Is that technical enough for you?</TD></TR></TABLE>
That is false. LS tranns suck period. Shorter gears = faster acceleration no matter what your set-up.
lilo_goki
15
Apr 7, 2007 11:29 PM
