Battery Keeps Draining! WHATS THE PROBLEM!?!?!
Old Nov 25, 2006 | 11:35 PM
SpoonEk253's Avatar
Default Battery Keeps Draining! WHATS THE PROBLEM!?!?!
Ok...well I took my battey to shucks the other week to get it tested and they said its no good. so i buy a brand new battery and installed it and everything works like normal. I also got my alternator tested to make sure its working 100% it is....
SO WHATS CAUSING MY BATTERY TO DRAIN?!?!?!? If i drive my car at least 3 days a week theres no problem, but when i just let me car sit a week and try to start it doesnt seem to have the juice anymore, WITH A BRAND NEW BATTERY TOO! No doors or anything is left open or on to drain it....or is theres something else that could be doing that? THANKS IN ADVANCE IF YOU CAN HELP!
Old Nov 26, 2006 | 07:17 AM
frostyrb's Avatar
Default Re: Battery Keeps Draining! WHATS THE PROBLEM!?!?! (SpoonEk253)
You have a draw on your battery. Pull off the neg terminal, hook a test light to it & put the test light on the neg battery terminal. If it lights up brite you have a draw. You might have to let it sit on the battery for a minute & then it will get dimmer. You can also do this with a mulitmeter. You don't want anything more then 40 mV. Then if you have more then that, you have to start pulling fuses untill you find what circuit it is on the you have trace wires from there.
Old Nov 26, 2006 | 09:00 AM
SpoonEk253's Avatar
Default Re: Battery Keeps Draining! WHATS THE PROBLEM!?!?! (frostyrb)
so after i find the fuse....what do i do from there? Do I pull the fuses from the fuse box under the hood or under the dash and what do you mean i gotta find the wire?
Old Nov 26, 2006 | 09:55 AM
b16a4's Avatar
process of elimination.
Old Nov 26, 2006 | 02:12 PM
SpoonEk253's Avatar
Default Re: Battery Keeps Draining! WHATS THE PROBLEM!?!?! (b16a4)
ok i did the draw test and i pulled all the fuses and relays and nothing seem to be the problem. the only difference in amp was the radio back up fuse i even did all the fuses under neath the steering wheel....then i took the ground wire to the starter and cleaned it and put it back on. ANY OTHER SOLUTIONS?!?!?
si_motor_spt
17
Mar 27, 2011 12:10 PM
Vt3c_eg
Jul 15, 2008 03:16 PM
gsrpedro
14
Feb 5, 2008 01:14 PM
Integ-boy
Nov 26, 2007 06:12 PM
biggdogg
18
Nov 26, 2003 06:32 AM
