b20v took a dump...
Old Nov 25, 2006 | 10:47 PM
@llmotorwhor3's Avatar
Default b20v took a dump...
Whats up guys,i think i finally did my motor in(CP 12:5:1's,Eagle rods,stock 72 head with CTR cams)while running my friends gsr hatch...When i hit thrid it had a sluggish feeling to it,and now it sounds like my valves are ticking like hell...My question is i got 500 bucks thats IT,can i rebuild my whole motor with valve seals,rings,headgasket and all for that amount? I just wanna get an idea....Thanks
Old Nov 25, 2006 | 11:18 PM
dude_123's Avatar
Default Re: b20v took a dump... (@llmotorwhor3)
Do a compression test to check condition of the motor, then do valve adjustment and do another compression test to see if anything have change. Valve adjustment will take care of the ticking.
Old Nov 25, 2006 | 11:46 PM
Default Re: b20v took a dump... (dude_123)
Did a compression test and came out 120,119,110,120...So i know my rings are almost non existant
Old Nov 26, 2006 | 05:13 AM
d16dcoe45's Avatar
They are all very close to each other? Did you open the throttle all the way when you did the test? I once forgot to open the throttle and my numbers where 50% of what they should have been.
Old Nov 26, 2006 | 07:43 AM
JCushing's Avatar
make sure the motor is warm and the TB is open all the way
MilFhunter001
May 13, 2010 08:29 AM
racer22
May 22, 2006 02:52 PM
Sport_Injected
Aug 25, 2004 09:21 PM
johnzm
Jul 26, 2004 07:46 AM
lazyguy
May 5, 2002 01:36 PM
