I have a k-series block question...
Old Nov 25, 2006 | 07:45 PM
blanco2314's Avatar
Default I have a k-series block question...
Ok i am building a k-series EK9. I need to know which type of block is better for running high boost (i am going to do the internals and all.) Which block should i use on a k20a2 type s head:
K24 block
K20a2 block
and
with having high boost which tranny would be best
5 spd
6 spd
or
6 spd LSD
Old Nov 25, 2006 | 08:14 PM
Miracle's Avatar
Default Re: I have a k-series block question... (blanco2314)
ME, PERSONALLY...
Since the K20A2 is already built for semi-high compression (11:1 OEM), I would go with a K24A3, which is 9.5:1. Unless you plan on adding dishtop low compression pistons to compensate for boost... I would go with the K24!1/3/4 setup.
And I would go with a 6 speed LSD setup on the tranny... better straight line and corner traction, and more gears
Here is a pretty cool FAQ thread, with numbers on a lot of motors you may be interested in... check it out... https://honda-tech.com/zerothread/1759092
Old Nov 26, 2006 | 04:00 AM
blanco2314's Avatar
Default Re: I have a k-series block question... (Miracle)
ya but if i go with that K24 block could it handle the boost im looking to do 15-30 pds? which block would be better to push that type of boost?
Old Nov 26, 2006 | 04:51 AM
Miracle's Avatar
It all depends on what you put inside the block to determine wether it will hold boost....
If you put high compression pistons, and a hundreded shot of nitrous, you are going to pop something REALLY quick.
It is all in your form and function of parts and machine work to get a block prepped for boost.
Forged internals, low compression pistons, forged crank, upgraded head/cams/valves/components.
Old Nov 26, 2006 | 07:56 AM
eMpAtHy's Avatar
if you're going to build the bottom end, i'd go with the k24. there is no replacement for displacement.
Old Nov 26, 2006 | 08:02 AM
NJslvrtypes's Avatar
People have run high boost on both K20 + K24's and I have never seen a sleeve failure. Obviously the K24 is going to give you more torque but the K20 has the rod stroke ratio better suited for revs. Its really a toss up in my opinion, whatever you can find for cheaper. I have 600+ K20's and K24's, but I have never seen a 10sec K24, LOL!
Trans wise, the 6 speed sucks. Stay away!!! My car eats 6 speed gears for breakfast! The only trans. I have remotely seen stay together with high boost is the base 5 speed. Not to mention the gear ratios are longer making it more ideal for high boost.
Just my .02 cents
Old Dec 1, 2006 | 01:07 PM
blanco2314's Avatar
Default Re: I have a k-series block question... (NJslvrtypes)
what k24 blocks bolt up to a k20a2 head? oand which block is the best to use (ill be doing all the internals with low compression and forged parts
integraboosted
Sep 1, 2006 06:46 AM
danny98r
Sep 12, 2005 08:09 AM
CANTFAZZDISCHIT
Jul 9, 2004 07:18 PM
b16 pwrd ek
Mar 24, 2003 04:50 AM
B18CHatch
Oct 18, 2001 03:06 PM
