Should the spindle nut be replaced when changing to new rotors?
Old May 9, 2002 | 08:31 AM
BLITZ's Avatar
Default Should the spindle nut be replaced when changing to new rotors?
The Helms manual says to replace the spindle nut. Is it necessary? Please give me your input.
Old May 9, 2002 | 08:39 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Should the spindle nut be replaced when changing to new rotors? (BLITZ)
It doesn't need to come off when changing rotors.
Warren
Old May 9, 2002 | 09:15 AM
reefer_bob's Avatar
Default Re: Should the spindle nut be replaced when changing to new rotors? (Warren)
Warren
Exactly... that doesn't make sence that it would recomend replacing it... Sure you read it correctly?
Old May 9, 2002 | 09:39 AM
BLITZ's Avatar
Ok now i feel dumb. Ok cut me some slack guys, I have never done it so this is my first time haha. So the 6 mm bolts are the only things holding the rotor in place? I am looking at pages 18-10 & 18-11 on the Helms manual. I just remove them & the rotor should come off? (of course it may be stuck so i need to use those 8x1.25 mm bolts to push it out right?) Thanks
[Modified by BLITZ, 10:44 AM 5/9/2002]
Old May 9, 2002 | 09:41 AM
Anderson's Avatar
do you have to remove the calipers if you want to replace your rotors?
Old May 9, 2002 | 09:46 AM
pyromaster's Avatar
Default Re: Should the spindle nut be replaced when changing to new rotors? (Anderson)
yes you will have to take off the calipers
here's a good link for you
http://www.bseries.net/html/garage/brakes.php
Old May 9, 2002 | 09:47 AM
Warren's Avatar
Wrong-Way Wang
Take off the caliper and caliper bracket. Unscrew set screw. Hammer the **** out of the rotor if it's stuck. Reverse steps w/ new rotor.
Warren
Old May 9, 2002 | 09:49 AM
Willard's Avatar
one more step...
-apply anti-seize everywhere.
Will
Anderson's Avatar
Old May 9, 2002 | 09:51 AM
GRM Scott's Avatar
25 Year Member
those brake retaining screws can be a real pain to get out...i got an impact driver and it failed to do the job...i drilled them out, and was amazed how easy it was to use some needlenose pliars to get the threaded shaft of the screw out once the head was gone.
Old May 9, 2002 | 09:52 AM
Anderson's Avatar
Default Re: Should the spindle nut be replaced when changing to new rotors? (Aleph)
anybody got a pic of da?
Old May 9, 2002 | 10:14 AM
reefer_bob's Avatar
The search function isn't that broken...
https://honda-tech.com/zerothread?id=157429
Search people, search!!!
Bakwoods
Sep 27, 2011 01:27 PM
rufridn
Sep 5, 2005 12:41 PM
onyx00
Jan 7, 2004 09:24 PM
FredoSP
Oct 1, 2002 07:50 PM
onyx00
Apr 24, 2002 07:33 PM
