lower ball joint/ lca question?
Old Nov 25, 2006 | 11:25 AM
B18CYAAA's Avatar
Default lower ball joint/ lca question?
94 GSR
I have a few centimeters between the lca and the boot for the lower the ball joint. Am I ready to pry out the axle? Do I need to remove the lca first?
Old Nov 25, 2006 | 12:15 PM
B18CYAAA's Avatar
Default Re: lower ball joint/ lca question? (B18CYAAA)
quick revision. Is it possible to remove the axle from the tranny without removing the axle from the hub?? Keeping the rotor and hub in place and prying the axle out from the tranny. Then lifting the axle hub and upper suspension off of the lca.
Old Nov 29, 2006 | 01:53 PM
boostedbigguy's Avatar
its alot easier just undoing the nut for the axle, is there a reason you dont want to do it that way? does the nut not want to come loose?
Old Nov 30, 2006 | 07:32 PM
B18CYAAA's Avatar
Default Re: lower ball joint/ lca question? (boostedbigguy)
the nut for the axle which is located in the center of the rotor? The car is up on jackstands and isn't coming down. If I try to take this nut out the rotor spins. If I put the car in a forward gear and take it off will that work.
Old Nov 30, 2006 | 10:59 PM
slooogsr's Avatar
If you have an extra person, get them to apply the brakes...... its worked for me a couple times.....
thw_goalie
Aug 12, 2012 10:39 AM
minvi
Jul 28, 2010 11:44 AM
crx18c1
10
Apr 17, 2007 10:17 PM
B18CYAAA
Nov 25, 2006 01:22 PM
homesauce
Mar 25, 2005 11:15 PM
