any DIY on power window and lock on a 92 - 95 CIVIC,, REWIRE THEM..HELP!!!
i brought the power door lock and window part's with the harness for the door.but i just found out..the indash wire are diffent..so i need to REWIRE THEM..ANYBODY KNOW the wiring diagrams PLEASE HELP....
OR ANYTHING TAT CAN HELPS ME..
its easier to get a floor harness from a chasis that had power options. If you are not good at soldering get the floor harness its plug and play.
well i'm good with that..that's why i wanna know the.. wire. details so i know where to solder them that's why
I tried finding this DIY on here that was good I thought I marked as a favorite at home but I can't find it Jacks repo or something like that.
I think you will need the harness ends( Not the door harnesses), that plugs into the frame side of the door ( meaning plugs into the door from outside while door harnesses are inside the door and are the male end of the connection). It reaches through the frame and connects at the door, for what your trying to do the other end would be cut (you would see loose wires hanging by the interior fuse box and by the ECU) and you will need both sides. I think colors match from side to side mostly. I went for the floor harness cause I have access to Junkyards and it was easier. I will look again for that site when I get home. Hope this helped a little. GL
yea..we need some input...
i have the harness from the door..and details.
i have the harness and i wanna rewire them.my self..and yea i know i need to connect them and leave wire hangin around.but i can make them and not going to hang around....but do you got any like diy wire infromation and where to connect to and stuff ?? please help..we need little more details..
here's the Link Iceysc they tell you what they need to do power window and lock
http://repo.jackmoves.com/v/er...81121
goodluck
goodluck
yea..i mean swaping the harness from the door that is fast..but doing the harness isnide the dash that might take a while cuz i cannot find that info...
hope there's someone that know and welling to share
Kyle700
Dec 10, 2014 11:32 AM
DAP97SI
Apr 22, 2011 05:28 AM
CaptivaBlue
10
Feb 27, 2005 10:24 AM
