Wiring Vtec
P28 ECU B16 Head
i know that pin A4 on my ecu is to vtec solenoid and i know d6 is for my vtec pressure switch? but on the actual vtec solenoid what one is the pressure? i already have the 2 wires ran through my fire wall. is that all i need?
SITE I USED: https://honda-tech.com/zerothread?id=1513794
The VTEC solenoid and pressure switches are two different things. The pressure switch is right under the solenoid. If that is what you are asking. Yes, that is all you need to wire.
an on the vtec pressure switch how many wires come from that because i thou only 2 wires go to the ecu, correct? and i see 2 pins? so what pin goes to the ecs? whats the other pin for?
need help connecting my v tec pressure switch to my computer, i have a 95 civic dx swap with a 95 ex my computer is already changed out i dont have no access to a harnes for the v tec pressure switch harness, also car does not kick in v tec at all and it is correctly wired to computer, need help?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic »</TD></TR><TR><TD CLASS="quote">NEXT QUESTION when pinning the v-tec wires into my ecu what do i use to hold them in. where can i the those pins?</TD></TR></TABLE>
Still looking for pins? I cut up a harness today. PM me.
nutball72
Aug 26, 2006 10:54 AM
